Odd engine problem, please help
Old Jul 19, 2025 | 02:35 PM
Jsouz50's Avatar
Jsouz50
I had a very strange thing happen with my engine today. I have a 97 f250 HD with the 351 Windsor. It was idling just fine and then all of a sudden, it dies. It didn't sputter and slowly shut off, but it was instant. Almost as if I took the key out and shut off the truck. I then started it back up and it struggled to start, but it did. but then it died soon after. It only would stay running if I gave it gas, so basically it wouldn't idle. After doing that a few times it wouldn't run at all. It would crank and not run. It seemed like it wasn't getting fuel. I let it sit for probably about 10 minutes and it started right up with zero problems. I let it run and idle for an hour and nothing happened. Any ideas what the problem could be? Where should I start and what should I check?
Switching the tanks made no difference, they both did the same thing. I had one of my tanks and the sending unit replaced a year ago. Along with a full tune up. Spark Plugs+ wires, distributor, etc
Old Jul 19, 2025 | 02:48 PM
88n94's Avatar
88n94
It doesn't exactly sound like a fuel filter problem, but when was the fuel filter last changed?
Old Jul 19, 2025 | 03:45 PM
Jsouz50's Avatar
Jsouz50
not sure if it was replaced, but I'm sure the fuel filter is fine. Last year when all the work was done, my mechanic also inspected the fuel system because I was getting no power from one of my tanks, he checked for anything clogged so I'm sure he checked it. Also as I said switching tanks didn't change anything so I doubt it's a filter
Old Jul 20, 2025 | 07:35 AM
Rusty Bucket Ohio's Avatar
Rusty Bucket Ohio
Was the tank you were using down low on fuel that possibly could have brought some bad gas or water into the system ? Condensation can bring in water that could cause what you described
Old Jul 20, 2025 | 08:26 AM
Scndsin's Avatar
Scndsin
There are about a dozen things that manifest as die/then run in this gen.
You need to run the diagnostic codes before loading up the parts cannon.
Old Jul 20, 2025 | 09:42 AM
Jsouz50's Avatar
Jsouz50
nope, I always alternate using tanks when one gets to a quarter. The other tank was at half too. And changing the tank didn't make a difference so I doubt it's a problem with anything in the tanks
Old Jul 20, 2025 | 01:19 PM
Jsouz50's Avatar
Jsouz50
i got a code reader and it is throwing code 212. the code says "loss of ignition diagnostic monitor signal/SPOUT circuit grounded.
Old Jul 20, 2025 | 01:21 PM
Jsouz50's Avatar
Jsouz50
i got a code reader and it gave me the code 212. it says "loss of ignition diagnostic monitor signal/SPOUT circuit grounded"
Old Jul 20, 2025 | 04:50 PM
Scndsin's Avatar
Scndsin
Your ICM/ignition control module mounted on the inner fender in an aluminum heat sink is what color?
Grey or black? Embossed with motorcraft or not?
Your diagnostic connector is inside cab/under hood?
Old Jul 20, 2025 | 05:23 PM
Jsouz50's Avatar
Jsouz50
it's black and it says motorcraft on it. I have read forums about people saying aftermarket ones suck. Maybe mine isn't working because it's old? I have no knowledge of it ever being replaced
Old Jul 20, 2025 | 06:25 PM
Scndsin's Avatar
Scndsin
There's a testing procedure that I don't have at my finger tips, maybe one of the folks here can post.
The ICM is one of 2 items that have history of die-cool-work.
The remote type w/heat sink don't often do it, but not un-heard of.
The other is the PIP/profile ignition pick-up (in distributor), which is supposed to give a code, but doesn't always.
Motorcraft PIPs are all but unavailable these days sadly.
Old Jul 20, 2025 | 09:02 PM
Soup bean's Avatar
Soup bean
I'm not 100 percent sure this covers '97's but read through it. What Does The PIP Sensor Do? (Ford F150, F250, F350) https://easyautodiagnostics.com/ford...-pip-sensor-do
It's a pretty good troubleshooting guide.
Old Jul 21, 2025 | 08:49 AM
manicmechanic007's Avatar
manicmechanic007
Better check the caps in your processor, could be one of a hundred things
Do a few things to diagnose it
Drive it around with a fuel pressure gauge taped to the windshield
Have a spark tester on it while you do that
There is a no start checklist in the book
It starts with the "BIG 3" testing "compression, fuel and spark"
Check the codes in there somewhere too, in case of a TFI failure or stator in the distributor problem, EEC trouble etc.
One of the best trucks made, buy a spare processor for it before you cannot and replace the caps in yours
MC Dig
Nov 1, 2020 09:38 PM
Nebrraska
Jan 15, 2014 06:14 PM
gallgood
6.2L V8
Jun 7, 2011 07:23 AM
c-bolt
Mar 5, 2007 11:36 PM
cbence
Jun 30, 2005 08:11 AM
