Sponsored by: Real Truck
Upstream o2 sernsor
Old Jul 14, 2025 | 08:29 PM
Capitolmasonry's Avatar
Capitolmasonry
Trailering
Upstream o2 sernsor
What is your guys recommendation for upstream o2 sensors? I got Bosch but guy at part store said they've had plenty returns on them? So now got me wondering. Thanks in advance
Old Jul 14, 2025 | 09:10 PM
aquanaut20's Avatar
aquanaut20
Go get an OEM sensor...
What makes you think you need a replacement, code or testing result ??
Old Jul 14, 2025 | 09:48 PM
ashleyroachclip's Avatar
ashleyroachclip
Factory is Bosch..
Old Jul 15, 2025 | 06:41 AM
projectSHO89's Avatar
projectSHO89
That tells me that either people are buying sensors based on guesses or faulty troubleshooting procedures. Getting your codes read at the auto parts store seems to be a major factor in both of those.
Old Jul 15, 2025 | 12:51 PM
Capitolmasonry
Trailering
2013 f250 6.2 4x4 (276,000 miles)
I did go get a scan. Came up with misfires in 2, 5 and 7. Also catalyst system below threshold banks 1 and 2. Bank 2 air-fuel ratio imbalance. I had a bad exhaust manifold so started with changing that out. Still light was on. So then went to changing out plugs and wires, reset computer. Ran with no light until I stepped on it. Engine light flashed then stayed on. Got back under hood noticed that thermostat was leaking a little fluid so changed that. Also got Bosch upstream sensors. Replaced them. Did fine on test drive last night and even got on it a bit. I still could feel the engine wasn't right. So now I guess its going to looking into coil packs. Anyone else have any suggestions?
Old Jul 16, 2025 | 09:13 AM
Lmueller7879's Avatar
Lmueller7879
3rd Gear
One of the things it could be is that the catalytic converters could be clogged up and not allowing for proper air flow for the exhaust. I had a similar problem and found that my O2 sensors were pretty much gone and the cats were very very clogged up. Once i changed it out and got stock oems i put my foot into it and i saw the difference it made.
Old Jul 16, 2025 | 12:14 PM
Capitolmasonry
Trailering
It turned out to be as simple as the purge valve. It was stuck open. I did more research and came across this so I thought what the hell ...I'll check it out. It was simple to test it and sure enough it was stuck open.
995.4SD
May 21, 2008 03:03 PM
870
Feb 15, 2008 09:23 PM
richert01
Escape & Escape Hybrid
Dec 22, 2007 09:48 AM
bhaggerton
1983 - 2012 Ranger & B-Series
Mar 1, 2005 12:20 PM
