Seat foam?
Old Jul 12, 2025 | 03:34 PM
g-money-55's Avatar
g-money-55
Seat foam?
Working on the seat for the 55. A few months ago I had purchased a 2" piece of memory foam for the seat bottom. In recent readings I'm seeing many other advise against 2" saying that is too thick. Question would a piece of 1 1/2 be better for the bottom and 1" for the back? Note I'm a pretty big guy at 6'3" 212# so it was tight enough as it was originally. Pics for fun!
Old Jul 12, 2025 | 04:57 PM
abe's Avatar
abe
That seat doesn't look too bad.
Is your truck a Custom Cab or a Standard Cab? Standard Cabs had no foam at all. Just burlap and cotton batting.
Memory Foam might be different but 2" might make you sit too high. So 1½" would be better .
Are your zig zag springs all good?
Old Jul 12, 2025 | 05:09 PM
g-money-55's Avatar
g-money-55
Yes, this is a standard cab and true it was all burlap and cotton originally. I was actually surprised to see it only had one zig zag spring that was broken and it was an easy fix!
Old Jul 12, 2025 | 05:57 PM
abe's Avatar
abe
I thought it was a Standard Cab because of the original seat upholstery. The Custom Cabs had a vinyl bolster at the top and was color coordinated to the body color. So the second picture has the new foam sitting on the seat?
Old Jul 12, 2025 | 06:31 PM
g-money-55's Avatar
g-money-55
No that's not foam. That was the original stuffing once the cover was removed. Not sure what that to later might be called but it was really soft. It appears to be three layers that made up the cushion. With burlap underneath
Old Jul 12, 2025 | 10:50 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Memory foam compresses to form around you. When you first sit on it and when cold it will be higher, but your body weight and heat will allow it to compress. I say use the 2". If you don’t like it you can change it later. That is the best part of doing the work yourself.
Old Jul 13, 2025 | 06:22 AM
JPMallory's Avatar
JPMallory
On my 48, I used 2 inch (luxe-hq) foam. For the seat bottom it's fine. It's a little too much for the seat back. If I were to do it again, I'd go thinner for the seat back, but still 2 inch on the bottom.
ron2565
Jan 14, 2024 09:31 PM
Centennial F100
Aug 13, 2023 06:14 AM
diggerrigger
Dec 16, 2021 11:21 AM
diggerrigger
Dec 15, 2021 03:17 PM
F100supercrew
Jul 1, 2018 04:26 PM
