Amp meter not charging
Old Jul 19, 2025 | 09:29 AM
  #31
tico47's Avatar
tico47
I am kind of at wits end with this thing now. I had the starter gone thru and was told it is in great condition, replaced the voltage regulator and still not showing a charge on the amp meter, I had the generator gone thru and it was found it had a broken ground wire, they fixed that and turned down the armature and said it was working fine and showing a charge. Installed it in the truck and it showed very little charge, polarized the the regulator and still the same. I went out with the truck last night it ran fine. When I came home it was dark out so I had the lights on about a half hour ride not showing any charge on the amp meter. I shut the truck off in my driveway and tried to restart it with no luck. This morning I went out and it started right up so I took it to interstate battery to have the battery tested and it tested fine both running and shut off. There is a problem somewhere but I have run out of places to look
Old Jul 19, 2025 | 10:35 AM
  #32
Brian1950F4's Avatar
Brian1950F4
How old and what size are your battery cables? They should be at least 2/0. I have had corrosion on the inside of my cables that was not obvious from the outside. So every time I checked the ends for corrosion, I moved them around enough to make a temporary connection. New cables fixed my problem. My local Interstate Battery custom made my cables at a very reasonable cost.
Old Jul 19, 2025 | 10:41 AM
  #33
abe's Avatar
abe
So true. Years ago I had starting issues, especially when hot. My cables looked good on the outside. I got new ones made. I cut an old one in half and the inside strands were corroded.
Old Jul 19, 2025 | 11:03 AM
  #34
tico47's Avatar
tico47
I am not sure how old they are, I have only had the truck since the end of May. Everything looks fairly new but I will check again. The previous owner had restored about 95% of the truck and I am finishing up all of the smaller stuff. I will give it a shot with the cables, thanks for your input
Old Jul 20, 2025 | 12:06 PM
  #35
tico47's Avatar
tico47
Okay guys I am going to throw a stupid question out there. 6 volt positive ground generator, what would or should be the correct output at the generator before the regulator? I am trying to narrow this problem down
Old Jul 20, 2025 | 12:25 PM
  #36
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
7 or more volts I believe is what you would be looking for wish some engine RPMs.
Old Jul 20, 2025 | 01:18 PM
  #37
tico47's Avatar
tico47
Okay, thank you for the info. I guess I will start a search for a generator. I just had this rebuilt but it's not putting out what it should be
Old Jul 20, 2025 | 01:31 PM
  #38
bmoran4's Avatar
bmoran4
A more thorough test is probably in order:
Old Jul 20, 2025 | 04:22 PM
  #39
tico47's Avatar
tico47
Thank you, I will give it a try tomorrow
Old Jul 20, 2025 | 09:37 PM
  #40
Brian1950F4
Sorry, I had the grand kids over. I didn't get out to my shop for pictures
Old Jul 20, 2025 | 09:45 PM
  #41
Brian1950F4
Old Jul 21, 2025 | 08:32 AM
  #42
tico47's Avatar
tico47
No problem
Old Jul 21, 2025 | 09:44 AM
  #43
tico47's Avatar
tico47
I would like to say thank you to all of you that helped me out with your knowledge and suggestions. After a lot of research and trial and error, I finally got this truck charging the way it should be. A simple adjustment to the regulator and it is running fine. Thanks again everyone. This forum is great
Old Jul 21, 2025 | 10:37 AM
  #44
hooler1's Avatar
hooler1
Good to hear Tico. Out of curiosity, what was adjusted on your regulator? Reason I am asking is on these mechanical type of regulators. Now days, how well are they really adjusted at the factory, or are they even?
Old Jul 21, 2025 | 11:25 AM
  #45
tico47's Avatar
tico47
A friend of mine is an electrical engineer and professor at WPI Colledge in Worcester, Ma. He did a tone of research and we tried a little test on the truck last night and found that we could make a slight adjustment on the armature side of the regulator.. He just cracked it open a little bit more and it made a ton of difference. That brought the generator up to the right output
