Sponsored by: Real Truck
TEST DRIVE NOISE
Old Dec 28, 2002 | 09:40 AM
lilguy's Avatar
lilguy
TEST DRIVE NOISE
Test drove an 03 250 SD TD and noticed a significant whine noise at 1500 rpms. Noise not from engine, Truck had 250 miles on it, would suspect Trans, any thoughts? LILGUY
Old Dec 28, 2002 | 09:43 AM
vze2372e's Avatar
vze2372e
TEST DRIVE NOISE
this may sound silly but was it in 4wd when you test drove it? my front end is solid as a rock but it makes a whine like straight cut gears at low speeds when the hubs are locked and the transfer case engaged - above 25 or so it blends in with the rest of the noises the truck makes so it's inperceptible. Just wondering....
Old Dec 28, 2002 | 10:15 AM
lilguy's Avatar
lilguy
TEST DRIVE NOISE
No, noise appeared after warm up(15 min drive).has to do with forward motion in gear. in netural rolling or in park noise not evident at 1500rpms.
Old Dec 28, 2002 | 11:54 AM
Quikirk's Avatar
Quikirk
TEST DRIVE NOISE
