Clapping sound???
Old Jul 6, 2025 | 11:23 PM
KRB94F150's Avatar
KRB94F150
Clapping sound???
Hey everyone, my 92 4.9 is making a strange sound only opon acceleration wail in gear, Im new to the 4.9 and much other macanical stuff. So i got no clue, ill add video. What do you think it is?https://photos.app.goo.gl/6QtnBNCs55UtibHi7
Old Jul 7, 2025 | 09:11 AM
manicmechanic007's Avatar
manicmechanic007
4.9's usually last forever with ZERO issues
I did hear a slight knock in the video
Try to narrow that down to a cylinder by pulling spark plug wires and seeing if the knock changes
Might be okay, might be normal
What weight oil are you using?
I'd only use 10/30 in that motor
Maybe visit a Ford dealer for the next oil change and see if they say anything about engine noise (ask them to check it)
I'd maybe pull the valve cover if I was convinced the noise was in there
They do get stuck valves once in a while from sitting and they do bend pushrods due to that sometimes
Run it with the valve cover off for long enough to watch all the push rods and valves rotate
Old Jul 7, 2025 | 09:43 AM
wwhite's Avatar
wwhite
Exhaust leak - cracked manifold, pipe or bad gaskets.
You should be able to spot it by seeing black soot at the leak.
Old Jul 7, 2025 | 10:55 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Only thing I heard was the p/s pump
Old Jul 7, 2025 | 11:14 AM
KRB94F150's Avatar
KRB94F150
ok ill take a look
Old Jul 7, 2025 | 11:18 AM
KRB94F150's Avatar
KRB94F150
[QUOTE=manicmechanic007;21609533]
I just put in 5w-30 but ill try the 10w-30 next time, or if it progresses. I have to replace the valve cover gasket anyways so good idea. Thanks
Old Jul 7, 2025 | 12:44 PM
Soup bean's Avatar
Soup bean
I agree with exhaust leak.
Old Jul 7, 2025 | 06:22 PM
spurredon's Avatar
spurredon
Sounds like exhaust leak to me as well.
Old Aug 17, 2025 | 09:24 PM
KRB94F150's Avatar
KRB94F150
Sorry for late reply
I got down to the manifolds and found one cracked on a arm and at some point it spit out the gasket between it and the block. Its all fixed now thanks alot. Now i can hear everything else wrong with my truck lol.
ZFLASH
15
Mar 1, 2023 02:32 PM
93Cobra
2017 Ford SVT F150 Raptor
Oct 26, 2016 09:26 AM
Gary Lewis
2015 - 2020 F150
17
Jan 4, 2016 12:24 PM
gman97005
May 1, 2015 10:44 AM
rideracelivemx7
Nov 18, 2011 10:06 PM
