Offroad & 4x4
limited slip idea?
Old Dec 6, 2003 | 04:43 PM
4xfordbronc's Avatar
4xfordbronc
limited slip idea?
I am currently replacing my dead spider gears and side gears on my 8.8 and noticed that on my clutch pack the two closest to the side gears have had their tabs destroyed and I found and cleaned out all the metal in the catcher at the bottom of the diff. I got replacement spider gears and side gears for $100 and got the clutch packs for $120 (does this price seem reasonable?) and when I replace the clutch pack if I add a washer or two from my old dead clutch pack will that help increase locking up of the rear? Just curious
Also, is there a way that I can rearrange the clutch pack so that I get better traction?
Gabe
Old Dec 7, 2003 | 10:46 PM
red_rocket's Avatar
red_rocket
yes.
your t-loc rebuild kit should come with a set of shims as well, a .005" .010" .015" etc.. You can also change the order, and use one of your old clutches, so you have 4 per side, instead of 3.
I did this for my stang, along with over shimming it, and loved the results. nice and tight.
