Motorhomes (Class A,B,C & Super C) F-53/59, E-Series E-350 / E-450 RV Cutaways, Econoline, Transit, Stripped Chassis, Bus Conversions
Old Jun 25, 2025 | 02:49 PM
kdinirons's Avatar
kdinirons
1st Gear
2000 f53 chassis. P00113 code. voltage too high. The 5.0 volt reference voltage is present at the switch (grey wire) . Grey/red wire is the return and it shows a perfect ground. The switch checked out with the 5 volts to the pin. A little heat and the voltage adjusts accordingly. Switch is good tested by itself. No matter what I do, I get -40 in my live data. I am afraid this means a new PCM. Ouch!! What am I missing?
Old Jun 26, 2025 | 05:15 AM
charlie g's Avatar
charlie g
FTE Community Team
welcome to this site,your post has been moved to the proper area to aid you more .good luck
Old Jul 4, 2025 | 12:22 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
P0113 IAT voltage too high
Next step is measure voltage at the pin on the PCM.
saauvenshine
Feb 4, 2025 07:01 AM
raye321
Apr 11, 2019 09:36 PM
michaeldove
25
Dec 6, 2011 09:22 PM
kmans777
1983 - 2012 Ranger & B-Series
Oct 1, 2005 08:01 PM
