Lead frame
Old Jun 23, 2025 | 07:21 PM
perryau1996's Avatar
perryau1996
Lead frame
Hi, it’s been a while since I’ve been on here. I replaced the lead frame on my 2013 f150. Got everything put back together and shifted good. After several miles I got code po962 (low control circuit for the pressure control solenoid A). Got stuck in 3rd. I didn’t have any codes before lead frame replacement. I replaced because it was shifting crazy and a wrench icon appeared. I went under and looked at the electrical connector to the transmission and found these frayed wires. I assume this could cause transmission limp mode with a code. The lever broke off when I tightened the connector when putting harness back on. I guess I’ll have to buy the harness or does anyone know where I could get that connector?
Old Jun 23, 2025 | 07:56 PM
2jhanna's Avatar
2jhanna
Maybe try junk/salvage yard
even if you can get connector with a foot or two of wires, you can do some cut/splice
RigCity
Oct 13, 2024 08:22 PM
Maglin
2009 - 2014 F150
Dec 22, 2021 05:48 AM
Necromancer
Apr 6, 2020 07:59 PM
tdl0
Electrical Systems/Wiring
Sep 10, 2016 12:44 AM
drewdole
Nov 13, 2009 09:57 AM
