Sponsored by: Auxito
Heater Problems
Old Jun 20, 2025 | 06:28 PM
Steve Leitzke's Avatar
Steve Leitzke
2nd Gear
Heater Problems
HI All,
My 1997 Ford F-150 w/ 4.2L Engine is being evaluated for repair or replacement. There is coolant in the oil. Since it doesn't blow a lot of smoke I suspect the head gasket is ok and the coolant is making its way into the oil via the water pump housing. There is at least one place oil runs thru the housing and if the gasket is breached the fluids will mix. Prior to this the heater would sometimes work and other times it would not, but right before it would start working again I would hear a swooshing sound. like pressure releasing. I suspect the heater core is plugged with "milkshake".
The question is whether the engine can be salvaged from the milkshake condition without completely tearing down and rebuilding. The rings and bearings, head gaskets, heads resurfaced at 130K, it's at 166K now. If you were to replace the engine, what engine would you replace it with. I use this truck periodically about 10-20 miles per month, so I don't need it to haul a trailer/boat. Suggestions?
Steve
Old Jun 20, 2025 | 08:33 PM
BareBonesXL's Avatar
BareBonesXL
Can't help on the questions but I wonder where this oil passage is. Here's a Motorcraft water pump for your 4.2.
https://www.rockauto.com/en/moreinfo...t=2208&jsn=717
Old Jun 20, 2025 | 09:15 PM
RLXXI's Avatar
RLXXI
Iirc It's in the timing cover directly behind the pump. On the 3.8's which is basically all the 4.2 is had a well known problem in that area of the engine, the 4.2's weren't as bad as the predecessor.
Old Jun 20, 2025 | 10:01 PM
STOFFERJ's Avatar
STOFFERJ
IF you’re gonna keep the truck I guess you could try a back flush and see if helps
not knowing how long it’s been run with a milkshake would lead me to toss the engine and grab another, If I were to do that, I’d grab a 4.9/300 and slap ‘er in modify some wiring exhaust etc and enjoy
Old Jun 20, 2025 | 10:23 PM
Steve Leitzke
2nd Gear
You are correct. The timing cover is between the water pump and the block. The gasket at the block is gapped allowing coolant to combine with the oil. Thank you for correcting me. Whomever worked on the engine before probably re-used the gasket. It is very thin and should never be re-used.
Old Jun 20, 2025 | 11:16 PM
BareBonesXL
Originally Posted by Steve Leitzke
HI All,
Steve
I would just fix the coolant/oil interface problem, run it the 10-20 miles per month and see if there's a major problem. Sounds like the only "problem" at this point is the fact that you found coolant in the oil. It still runs. Oil-water can still lubricate. Good luck.
Old Jun 21, 2025 | 11:09 AM
RLXXI's Avatar
RLXXI
Common problem as I mentioned, it's why they redesigned the V6 and came up with the bullet proof 3.7 V6 in 2011.
V10man
Apr 6, 2025 11:09 PM
Fastfwd
Jan 11, 2015 04:48 PM
Aerospace_ITGuy
Mar 2, 2013 09:53 AM
Fordgrl30
1997 - 2003 F150
Jan 14, 2008 01:22 PM
