Ford 300 water pump
Old Jun 16, 2025 | 10:55 PM
Chartis's Avatar
Chartis
4th Gear
Ford 300 water pump
Hey guys I need help.
I’ve got a 92 f150 300 2wd
when I first bought the truck I replaced the radiator because it was cracked
I had troubles with overheating when idling
so I replaced my fan still had troubles so then replaced water pump, thermostat and hoses.
I have now been through 4 water pumps in 2 year all have started leaking out the weep hole. And now it has just started again.
is it just faulty pumps or do I have something wrong.
my temp gauge stays on cold after I replace my thermostat, before it was reading normal (half way). Could it be a faulty thermostat or something plugged?
Old Jun 17, 2025 | 03:37 AM
Truckwardo's Avatar
Truckwardo
Maybe get one of those caps that let's you know the pressure. Other than that excessive belt tension or out of balance or Chineseum curse.
Old Jun 17, 2025 | 06:13 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I’m thinking the pump is bad. The local shop replaced the rack and pinion in the Outback three times with a reman from Napa. They finally gave up and used a new rack. It has been fine since then. Did you buy a good name brand pump or the store brand from the local parts store with the lifetime warranty that you spend a lifetime replacing?
If you used a “fail-safe” thermostat I can almost guarantee that it has already failed. I tried one of those several years ago. It worked for two weeks.
Old Jun 17, 2025 | 08:35 PM
Chartis's Avatar
Chartis
4th Gear
Out of balanced???
Old Jun 17, 2025 | 08:47 PM
Chartis's Avatar
Chartis
4th Gear
Yes I used 2 oreily pumps (Murray) and 2 Napa name brand pumps. My thermostat is a oreily brand, but my temperature gauge has always read cold since replacing it.
Old Jun 17, 2025 | 11:15 PM
My4Fordtrucks
Zero confidence in Napa parts. I haven’t used the O’Reilly pump
but it might not be any better than the Napa pump.
Yep. Sure seems like the new thermostat is already bad.
Old Jun 20, 2025 | 11:32 AM
TobyB's Avatar
TobyB
I'd check the tensioner just to make sure it's not binding-
if it sticks, it can put a lot of pressure on the belt...
t
it's probably not, but really easy to test.
Royson12
16
May 31, 2014 07:19 AM
Broncobudy
1978 - 1996 Big Bronco
13
Sep 2, 2011 05:43 AM
Old Bomb
Oct 28, 2006 12:42 PM
gramps10
13
Aug 29, 2004 11:15 AM
lloydbob1
13
Apr 29, 2004 01:03 PM
