390 Fe 5 speed options
Old Jun 16, 2025 | 07:10 PM
77390fe's Avatar
77390fe
3rd Gear
I got a 1977 F-250 single cab short flat bed for Christmas one year and thought that it was amazing. Up until I flipped it and replaced the dry rotted 37s with brand new and wider 40s, however I've come to the realization that the 4 speed it has is hurting the engine with the large dip in rpms at every shift. I put a Holly EFI Sniper 2 on it and it helped wake up the engine a lot but I still feel like it would preform better with more gears where the dip in rpms are not as steep.
All this to ask what are the 5/6 speed manual options that will either bolt directly or bolt with minimal fabrication?
Old Jun 17, 2025 | 06:06 AM
stryder's Avatar
stryder
You're problem isn't necessarily the transmission. You put 40 inch tires on a truck designed for 32 inch tires. The solution is to regear the axles to compensate for the increased tire diameter. For that we need to know the current gear ratio. Decode the door tag or look for a tag on the rear axle assuming it's all original. I can venture a guess that it's 3.55, as that is common for a lot of 70s trucks. Some had 3.25:1. If 3.55 is correct you need at minimum a 4.10 ratio. Ideal would be 4.30 or possibly 4.88 if you have 3.25:1. Changing the ratio to a lower gear (numerically higher) will makes the drop in rpm less severe when shifting gears.
Old Jun 17, 2025 | 04:20 PM
tjc transport's Avatar
tjc transport
i ain't rite
there is no current 5 or 6 speed trans that will bolt to the 390. for that, you will need a medium duty truck trans like a clark or eaton trans from a 70's F750
Old Jun 17, 2025 | 06:11 PM
85e150's Avatar
85e150
Well, nothing cheap. IMO forget the old big truck transmissions. You'd be better off with your current transmission.
High dollar options:
https://americanpowertrain.com/shop/...paOVGLC2Lsq2U2
https://www.moderndriveline.com/shop...ern-driveline/
A fellow traveler:
https://www.ford-trucks.com/forums/1...behind-fe.html
But the prior post is correct--your axle ratio is the main culprit here.
Old Jun 18, 2025 | 07:24 AM
elkdozer's Avatar
elkdozer
Trailering
Speed Gems also offers an adapter kit set up to adapt a small block ford 5 speed from a mid 90’s truck to an FE.
Old Jun 18, 2025 | 07:02 PM
77390fe's Avatar
77390fe
3rd Gear
The rear end has been regeared to I believe 4.11 maybe 4.10 but I guess that Im just wanting more out of something I wont?
Old Jun 19, 2025 | 07:10 AM
stryder's Avatar
stryder
Easy enough to verify. Lift rear tires off the ground and put in neutral. Turn the tire by hand one revolution and count how many driveshaft rotations. Should turn at least 4.
If you do indeed have 4.10s, the next option would be to source a close ratio toploader 4spd. Identified by a RUG-AD marking. The T18/T19 or NP435 that you have are wide ratios. Which is why you have the big drop in rpms between shifts.
You could also find a close ratio M5OD for the conversion, but that will not be an easy task as full size trucks got the wide ratio version.
Old Jun 19, 2025 | 02:12 PM
tjc transport
i ain't rite
i would not put a M5OD behind a 390. i think there will be too much torque for the M5OD.
Old Jul 18, 2025 | 09:11 AM
the_hetz's Avatar
the_hetz
This not correct. The RPM drop at a given RPM, say a 2500 RPM shift, will be identical between 2 different final drive ratios, all else held constant.
All numbers here are arbitrary, for comparison:
6.56:1 final drive; shift @2500 RPM from 1.71:1 to 1:1 gear ratio. This drops you to 1461 RPM, around 20.2 MPH shift point
2.73:1 final drive; shift @2500 RPM from 1.71:1 to 1:1 gear ratio. This drops you to 1461 RPM, around 48.5 MPH shift point
Old Jul 18, 2025 | 09:20 AM
the_hetz's Avatar
the_hetz
You are out of power. Your fuel mileage is going to be garbage with tires that big, no matter what you do.
I'm calculationg that a change to a 4.56 ratio would give you a net of around 230 more RPM @60 MPH, around 2300 RPM. 4.88 gears would get you up around 2470 RPM, which would be a tad more than what a "stock" pickup would run @60 with 3.73 gears and normal height tires.
70_F250_390
Oct 24, 2011 04:25 PM
dwardle
19
May 19, 2009 04:27 PM
morrigj83
Oct 9, 2004 01:21 AM
mcompton1973
1978 - 1996 Big Bronco
Mar 30, 2004 10:54 AM
fordman428
Dec 22, 2003 10:22 PM
