93 E350 clutch
Old Jun 15, 2025 | 05:04 PM
BSF350's Avatar
BSF350
93 E350 clutch
I have a 93 E350 (351W) and would like to add a clutch pedal. I believe the 91 model was the last year with a standard. Does anyone know if a F series or Branco pedal will bolt to the 93 firewall?
Old Jun 16, 2025 | 06:59 AM
manicmechanic007's Avatar
manicmechanic007
Truck and van pedal supports are NOT interchangeable
That's because they used the "mexican jumping bean" OD 4 speed transmission (smaller car trans)
I believe those floor shifted vans ended in 1989
That is the pedal support you need
The only shifter that will work is a "pile" that if you find one, will not work well and rebuild parts are impossible to find at best
That said, DO IT
It's fun shifting those old vans
Old Jun 16, 2025 | 12:39 PM
BSF350's Avatar
BSF350
Thanks. I read ford stopped putting standards in 91. 89-91 van clutch pedal is what I will look for over time. I have a T5 with the shifter close to the gearbox that I think will put it through the floor at a good spot
Old Jun 17, 2025 | 07:32 AM
manicmechanic007
That should work
The doghouse might fight you, but can be modified or dealt with
Like to see some pics while doing it
Natcox012
Mar 19, 2015 08:39 AM
qquake2k
Jan 12, 2015 05:30 PM
Mtnplow
Sep 6, 2011 08:03 AM
Chicken_Fried
Sep 13, 2009 10:52 PM
FordPerf300
Aug 19, 2003 02:05 PM
