Tailgate question
Old Jun 14, 2025 | 09:22 AM
steelholder's Avatar
steelholder
Tailgate question
From what I know, there are 2 types of tailgates offered for these trucks. The one with a panel and one without. Are these both the exact shape if panel is removed? I want to add the panel to a "non panel" model by drilling holes in the appropriate areas. is this possible?
Old Jun 14, 2025 | 11:01 AM
Junktownbill99's Avatar
Junktownbill99
The panel is aluminum, but with careful measuring and drilling, that may be possible.
Old Jun 15, 2025 | 01:20 AM
AuroraGirl's Avatar
AuroraGirl
my understanding is the XLT (panel) tailgate is heavier and stronger but thats just from the self-reported experience on a thread i made on this topic a few years ago.
My tailgate is bowed in the center a bit on the inside (I think from sitting on it by large people), but its externally straight , its like the second one.
Old Jun 15, 2025 | 05:27 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I would expect it to be very easy to find a good used tailgate in your color with stainless trim out there in California. Hold onto your plain tailgate if you change your mind or sell it to recoup some, if not all, of the cost of the other tailgate since there are people searching for the base model tailgate
Old Jun 15, 2025 | 08:02 AM
manicmechanic007's Avatar
manicmechanic007
The tailgate sheet metal is different under that panel
Big holes to mount the panel, and a different shape due to the panel
I'd get a tailgate with the panel if you want one
Old Jun 15, 2025 | 08:08 AM
steelholder
is it? I put the panel over a tailagte and it was a perfect fit minus the holes.
Old Jun 15, 2025 | 09:06 AM
Scndsin's Avatar
Scndsin
Pulled my panel for protection.
Used stainless screws, washers & acorn nuts to fill holes.
Coated bottom washer with RTV, pressed to glass, let dry & trimmed to seal.
Plane panel is the same, just not drilled.
NOT green, just a reflection.
Old Jun 15, 2025 | 09:14 AM
manicmechanic007
They do fit if you drill the holes
The tailgates are different IIRR
Old Jun 15, 2025 | 12:56 PM
My4Fordtrucks
Would you explain what that means? The shape/ stamping of the tailgate is the same on ‘92-96 trucks that have the decal. The previous generation had the FORD stamped in the sheet metal under the stainless panel.
Old Jun 15, 2025 | 02:13 PM
steelholder
I think he meant to say everything is the same except the holes needed to mount the panel.
Old Jun 15, 2025 | 10:54 PM
AuroraGirl's Avatar
AuroraGirl
one of these days we should compare weights of tailgates in good shape and see what we find
kgwin1984
May 7, 2025 06:13 PM
Oldcrowbarber
Jan 30, 2018 10:11 AM
1985 Bronco
1978 - 1996 Big Bronco
May 27, 2015 11:45 PM
1997fordf350
May 9, 2013 06:45 PM
