223 Clutch install issues
Old Jun 10, 2025 | 10:16 AM
8pack's Avatar
8pack
I am posting here in the 61-66 Forum hoping one of you guys might have some addution perspective on my clutch issue in my 1955 F250 223 IL 6. I also posted this in the 57-60 forum. Trying to get as many people to give input as possible as maybe someone else already experienced the issue.
1962 Block
1955 Bell housing
11" Clutch
Instead of rewriting everything I was hoping you might check out the 2 threads below.
The first thread goes though all the measurements of my flywheel etc. and the ultimate clutch selection.
https://www.ford-trucks.com/forums/1...l#post21561676
The second thread goes through the current issues with the install.
https://www.ford-trucks.com/forums/1...l#post21589947
Any assistance would be much appreciated!
Old Jun 10, 2025 | 01:26 PM
Crop Duster's Avatar
Crop Duster
Seems you have some mismatched parts. Here is a parts list from a NumberDummy post for a 223. NAPA's web site will generally take Ford part numbers.
Measure the diameter of the clutch disc. 223 6 cylinder should be 10."
Clutch disc, pressure plate, throwout bearing, throwout bearing hub, and pilot bearing. Replace all these parts. NAPA is the best source.
Original Ford Part Numbers
1-B7C-7550-A .. Clutch Disc-10"
1-C5TZ-7563-B .. Pressure Plate-10"
1-B3TZ-7561-A .. T/O Hub
1-C0TZ-7580-B .. T/O Bearing
1-B-7600-A .. Pilot Bearing
Keep greasy mitts off the clutch disc when installing a new one. Otherwise..
Old Jun 11, 2025 | 12:02 PM
8pack's Avatar
8pack
Thanks. Original was an 11" inch clutch but I may have to go to a 10" given the set up you listed is proven.
Thank you!!!
Old Jun 12, 2025 | 04:31 AM
Crop Duster
Here is another post from ND. This is from the 48-56 forum. If you do some advanced searches in all the forums from 48 to 66 using NumberDummy in the username you can get a lot of info on original part numbers. Over the many years he was active he posted every part number in the book. He did mention that all the 4 speed trucks got 11-inch clutches.
C5TZ-7550-D (replaced B6D-7550-D & 81T-7550) .. 11" Clutch Disc / C0TT-7563-A (replaced B7Y-7563-A) .. 11" Pressure Plate.
Apps: 1961/64 F100/600 223/262 I-6 / 1957/60 F100/250 223 I-6.
Disc only: 1938/47 Commercial (1/2 ton), 122" wheelbase (3/4 ton) truck / 1948/51 F1/F6 226/254 L-6, 239 flatty / 1952/56 F100/600 215/223 I-6.
Here is one from this forum.
Ford didn't supply the hub with the bearing on 223/262/292, both parts were sold separately.
B7AZ-7561-A .. Throw Out Bearing Hub / Obsolete ~ Available NOS & from auto parts stores.
C7AZ-7580-A .. Throw Out Bearing ... It's the same 3 & 4 speeds, was also used on 1965 240/289/352/390 Passenger Cars, 1966 Bronco 170/289.
Hardsun
Jun 23, 2021 07:16 AM
hail destroyer
Jul 6, 2019 08:41 PM
riotwarrior
1978 - 1996 Big Bronco
15
Dec 9, 2014 01:04 PM
crewforce
Aug 14, 2011 08:41 AM
worldstoreone
Jul 24, 2009 10:08 PM
