223 Clutch install..
Old Jun 28, 2025 | 05:28 PM
  #31
8pack's Avatar
8pack
I had to take the shifter out to put install the floor mat today.
Before I took it out I could move the shifter through all the gears. When I put it back in I could run through 1-4 with the clutch pedal depressed, 2-4 with the clutch pedal up and I could not get into reverse in any situation. I am guessing because 1st and Reverse are non synchro gears the teeth are not lined up and when it rolls or I get it running that will resolve itself?
I just want to be sure I don't have a clutch issue. It seems odd things changed after I took the shifter out and put it back in.
I also have about 1.75" free travel in the pedal which feels like a lot at least compared to my Camaro.
Old Jun 28, 2025 | 06:50 PM
  #32
Bvas's Avatar
Bvas
Running or not, my 4 speed goes in reverse easiest when going from second to reverse.
Old Jun 28, 2025 | 07:08 PM
  #33
8pack's Avatar
8pack
Clutch in or put or it doesn't matter?
Old Jun 28, 2025 | 07:12 PM
  #34
Bvas's Avatar
Bvas
Clutch in.
Old Jun 28, 2025 | 07:26 PM
  #35
Bvas's Avatar
Bvas
You may have to give it a little jiggle and/or bump.
With reverse and first unsychroed things don’t always go in smoothly.
Don’t tear things apart if you can’t get it. If you had it before, I’m sure you’ll be fine.
Old Jun 28, 2025 | 08:53 PM
  #36
abe's Avatar
abe
I wouldn't worry about the free play in the clutch pedal. This 55 F250 with a 6 banger is not a high performance Camaro! LOL
Old Jun 29, 2025 | 06:24 AM
  #37
8pack's Avatar
8pack
0-4mph in first gear in 2.9 seconds.......I don't know, I think you underestimate it.
Old May 16, 2026 | 12:53 PM
  #38
ManFordman2's Avatar
ManFordman2
I believe that would equate to 60mph in 43.5 seconds. 😁
Old May 16, 2026 | 02:06 PM
  #39
8pack's Avatar
8pack
It's funny this popped up today. I drove my Camaro about 1 mile with no glass bumpers hood etc before it went into the body shop for paint. I haven't driven it for 7 years as it was stuck in a different body shop since 2019.
Any way I have a 5 speed Hurst TKO transmission and when I sat down I couldn't figure out what was wrong. The truck shifter lever moves about a foot left to right in neutral and about 10 inches between gears. My 5 speed transmission moves less than 2 inches back and forth in neutral and less between gears.
I couldn't figure out whether I was in neutral or what gear I was in!
It takes 2 seconds to get between gears on the truck before you even think about how fast you are going. So 43 seconds is about right!
samntx
Feb 19, 2020 12:27 PM
tracyclifton
Mar 24, 2015 08:32 AM
hillcountryflt
Dec 23, 2014 07:23 AM
BigMikeUGA
Dec 31, 2011 07:38 PM
