Isulation On Shifter Cover
Thanks.
I did not look for one for mine as it was also just falling apart also. I would think if you can find some closed cell foam it would be ok.
I dont know what it is used for but I am not running anything and I dont get any smells and dirt in the truck but I also have 2 good rubber boots, main trans NP435 and over drive lever, and then carpet.
81 F100 4x2 w/ NP435 & over drive
Dave ----
I also ordered these foam o-rings (removed the center and stuck two together) and replaced the rotted out foam gasket between the transmission and the shifter hump: https://www.ebay.com/itm/31405511246...d48747c6d56d2c
