03 E350 trans problem
Old Jun 4, 2025 | 06:02 PM
pbarsoum's Avatar
pbarsoum
Trailering
E350 with V10. Trans doesn't shift until higher rpm when a/c is on. Transmission fluid temperature sensor? It won't downshift properly either. Otherwise it shifts fine until I turn the a/c on. Even after I shut the a/c off it seems to be stuck in that shift sequence until I turn the key off then back on.
JWMJR91F250
Bronco II
Oct 6, 2022 02:33 PM
bubbasz1
Feb 26, 2009 06:26 PM
mike28
Dec 26, 2007 10:05 PM
90 AWD
Aerostar
Oct 21, 2005 09:22 AM
