1988 ford f150 tachometer problem
Old Jun 3, 2025 | 10:24 AM
1988 ford f150 5.0's Avatar
1988 ford f150 5.0
4wd Low
I have a 88 ford f150 5.0 and we got the truck and it was efi and had a blown head gasket so we fixed the blower head gasket and put a carburetor on it with a new different distributor and I have a ton of cut wires the are coming from the cab and I have a green wire coming out of the distributor I know that’s for the tachometer and my question after all that is what’s the color of the signal wire coming from the rpm gauge and do I just connect it to the green wire coming out for the distributer ? Thanks!!
Old Jun 3, 2025 | 11:48 AM
Truckbuck's Avatar
Truckbuck
It should a be dark green/yellow wire coming off of the ignition coil connector. This will go through a resistor in the wiring harness.
I don't know the distributor you are using so I can't help with wiring that into the truck.
Old Jun 5, 2025 | 06:46 AM
rla2005's Avatar
rla2005
Should be a Dark Green/Yellow wire going to the factory tachometer (right side of this diagram):
The factory tach on the V8 trucks had a series limiting resistor for some reason. That resistor is located in the engine bay. An aftermarket tachometer most likely does not require that resistor. Refer to the OEM documentation.
kscooperbe26
Aug 12, 2022 10:26 AM
Mdhanners
21
Dec 7, 2021 12:40 PM
Mdhanners
Oct 21, 2021 08:33 AM
planethax
18
Apr 3, 2008 08:25 PM
