Blower only works on maximum settings
Old May 31, 2025 | 10:16 AM
excursion_7.3's Avatar
excursion_7.3
On every vehicle I have ever owned it has been the blower motor resistor. What is it likely to be on the Ranger?
Family has sensitive eyes due to Lasik and the blowing air is overkill.
Thanks.
Old May 31, 2025 | 07:44 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Blower motor resistor is the first place I’d check.
Old Jul 2, 2025 | 09:20 AM
RTR336's Avatar
RTR336
6th Gear
Every once in a while when I hit a large bump my fan will get stuck on high. I can go under the hood and play with the plug beside the fan and it’ll quit. It doesn’t do it often enough for me to dig into it further. 😂
Old Jul 4, 2025 | 09:08 AM
tomw's Avatar
tomw
Blower resistor is the most likely. Speeds other than max use resistors in series/parallel to reduce voltage and lower blower speed. Generally not an expensive item.
Older models have them in the wall of the heater plenum under hood. Simple unplug-unscrew-remove-install-screw-plug...
tom
dfiske
34
Nov 27, 2013 12:32 AM
cwnitsuj
2004 - 2008 F150
Aug 7, 2013 07:19 AM
CanadianSmokie
Jan 4, 2008 11:49 AM
StephenKnight
Jun 23, 2003 11:53 AM
