Any good camshaft........
in my opinion generic grinds are a thing of the past. all you need to know is the name Brent Lykins. talk to him and get a cam spec'd for your exact application. preferably a roller.
I'll check them out
Many many moons ago my oldest sister had a boyfriend with a purple 440 6pak Cuda with the infamous Pistol Grip Shifter..
Back in 2005 I re-camed a 1972 390 2V in a pickup. At the time I was working for a company named Hi-Tech Racing and one of the owners had a cam custom ground for low compression engines he called a Reactor. He claimed the overlap allowed for more of a cylinder charge due to its unique over lap.
The '72 390 2V had 8.7:1 compression so I thought it was the perfect cam. I had a intake and carburetor off a 1966 390 GT and a set of heders so I figured it was the perfect cam. One of the old guy there told me the only cam you put in an FE was a 428CJ cam, again this was 20 years ago.
A good friend of my has a 1969 Mach I with a 428 SCJ 4-speed with no PS. It has always been a garage queen and to this day it only has about 27k miles on it.
I don't think its been out of his garage for more than 50 years.
We used to take it down on State Street one in a while to pick on the other muscle cars, Rod was the master at launching his Mach I.
He spanked everything across the intersection with barely spinning the tires.
I used to LOVE the low end torque.
In the late 80s I was living just outside Denver CO and had become friends with a guy named Joe Novak, a big time Ford drag racer.
At one time he had a partner and they actually owned a Thunderbolt. He owned a few different cars that he raced like a factory 1969 Mustang convertible with a 428 SCJ which was one of his most successful cars.
When I met him he had a 1968 Fairlane Cobra with a 428CJ with a C6. He ran a stock class.
He had a picture on his tool box, he worked at a large Ford dealer in Denver and coming off the line his right front tire was about 3" off the ground a "stock" class.
He has two ford 2 tone farm truck that both had 428CJ in them.
I asked him what he shifted his 428 at and he told me 3600 RPM. His best time at Bandimere Speedway in the mile high city was am 11.76 and that was before he replaced the Detroit Locker with a spool and replaced the driveline with an aluminum one.
This is why I was leaning soo hard on a factory 428CJ cam, until you mentioned weight.
I've had some pretty bad luck with health issues over the last two years and my funds unfortunately are limited.
No custom grind or roller cam for me.
My truck weighs 6700 bs with my ATV in the bed and I plan on towing my small travel trailer that I'm guessing weighs around 6500 lbs loaded.
410, 1966 390 2V with a 428 crank and 10>5:1 compression.
Edelbrock Performer intake, Holley 650 cfm and a set of Hedman Heders.
This is what I need the right cam for.
even if you go with a flat tappet Brent can do those too, it's just going to be more limited with the ramp profiles that are possible.
I lowest my truck will probably ever see is 4200 ft.
It would be nice not running oil that's $12+ qt.
My 410 was rebuilt back in 1972 and was never stated until I bought it a few years ago, the rings never seated.
Worrying about the cam going flat was never an issue.
My how things have changed.
