Stumble and backfire during acceleration
Hope I'm posting in the right place. I am completely out of ideas on this one and would appreciate any input...
I have a (mostly) 1983 F-150 with the 300 inline 6. Somewhere along the way a previous owner welded up a custom intake manifold and bolted a 2 barrel Holley carburetor. It's ran great the 5 years I've owned it up until the following.
In the fall the truck stated stumbling and loosing power on acceleration. This got worse to the point it would completely die out and stall within a mile from the house. I parked it up for a while and am just getting back to it now. I rebuild the carb which helped and the trucks now idling great. Whenever I actually drive it though, it'll stumble when shifting and backfire. The new spark plugs quickly get extremely sutty throughout my attempts to fix this. Here is a list of all that I've done so far:
Double check the carb is reassembled correctly
Checked the accelerator pump is not torn and functioning correctly
New gaped spark plugs
New spark plug wires
New ignition coil
New distributor advanced by 12 degrees
New fuel filter
The float level is set correct as per the sight plug. The adjustment screws are backed out about 1 1/4 turns.
Anyone got any other ideas?
To me it sounds like a 2300 as it has a sight plug to check the float bowl level.
Next do you know if it is a 350 CFM or 500 CFM, 500 tend to be too large for a six.
As for running rich, when you rebuilt the carb did you replace the power valve (PV)?
What was the value I am guessing 6.5 as I think that is what comes in rebuild kits.
What dose your truck have for vacuum at idle? As a start for the PV it is half when the idle vacuum reading is.
Also if the motor backfired up thru the carb it most likely blew out the new PV as old Holley carbs did not have the anti-backfire check ***** in them.
Dave ----
New ignition coil
New fuel filter
But it was running good with this setup before and not running poorly & rich and why I pointed to the carb a blown PV will make it run rich as it leaks fuel.
Dave ----
For a quick test, engine at idle, try turning in the idle mixture screws all the way closed. The engine should starve for fuel and die. If the power valve is leaking, the engine will continue running. It may even idle a little more smoothly as you close off the normal supply of fuel, so the mixture is not so rich.
wouldn't be an issue.
Karl made a real good point though. When I crank the mixture screws in it does seem to run even smoother. I'll attach some pictures of the ol' girl on her homemade throne as well as the model. It's a 0-4412S by the looks of it.
https://www.holley.com/blog/post/how...xn4OEjeM6EfvwB
On a Holley the PV is a go between from idle to high-speed parts of the carb to help from running lean.
Also if holding steady throttle when driving and you feel "surging" the PV is just at the "tip in" point and opening & closing and you would need to go larger or smaller to stop that.
I have only had 1 carb, a 2300 also, that did that and think I went larger and it ran great after that.
Thing to know about the Holley 2300 it is half of their v4 carbs and get tuned the same way, just half of it.
BTW the Holley 2300 is a direct bolt on replacement for the Motorccraft 2100 / 2150 carbs used on the Ford & AMC v8's and you can use the factory air filter and no one will know you have a Holley on top of the manifold
Dave ----
4.5 was that the one from the rebuild kit? All I have ever seen were 6.5 in kits.
Do you know what your vacuum reading is at idle in gear if auto?
As a starting point they say you want a power valve half of what idle vacuum is.
Most good motors have 18 HG or more at idle so half is 9 HG so dont know why they put 6.5 in the kits?
To use the 6.5 in the kits your vacuum would be 13 HG.
The 4.5 you would have 9 HG of vacuum I dont even know if the motor would run with that vacuum?
Dave ----
I've ordered a 8.5 PV (I know there's a 9.5 but 8.5 is the only one I can get cheap and quick in Canada). It'll be here Monday. What I can't understand is how the truck ran so well after the last rebuild when I used the same AED rebuild kit that came with the 4.5PV. Unless I forgot to swap out the PV that time? Unfortunately, I have lost track of the PV I took out of the carb this time.
I'll let ya's know how it goes.
https://www.ford-trucks.com/forums/1...l#post21581960
As Dave mentioned, 4.5 is probably too low with a stock cam. That could be a factor if the mixture is too rich. Typically you'd want 8.5 or so. 4.5 is something you might see with a hot cam and resulting low manifold vacuum.
I think we got this situation sorted with that power valve. I put the new 8.5 in and headed to town and back (60mi). It backfired twice. I picked up new spark plugs, air filter, a can of Sea Foam and did an oil changed. I've put another 60mi on since with no backfires or stumbles at all.
Thank you Karl and Dave especially.
