Break Away Cable
Old May 27, 2025 | 04:50 PM
Phillbo's Avatar
Phillbo
Break Away Cable
I think that is what it's called... The small cable you attach to the truck that gets pilled out and engages the brakes if it hops the hitch.
How long and what is the correct routing.
Mine I believe is all wrong. From the factory it is about 8" longer than the safety chain when pulled tight and they have it routed under the tonuge and woven into a couple links on the chain.
My thoughts- The cable should be slightly shorter than the chains when hooked to the truck with the assumption that the brakes should be applied prior to the chains reaching full stretch.
The cable should be routed so as to pull in the same direction that the pin will come out. Mine is routed down under the tongue while the pin is oriented horizontally. My thought her is that this set up will work as far as getting the pin pulled but will most likely destroy the plastic housing it's in rendering it unusable and needing to be replaced. So, I feel I need to route the cable over the top of the tongue and then to the truck (this looks like it leaves the cable exposed. I route my 7pin connector through the clamp I use to secure the tongue latch so maybe this could be routed through it as well???
Sorry so long winded. Just looking for opinions as I feel the current set up is useless unless the safety chain breaks and the cable is stretched. I'd like it to be set up where the pin would be pulled just shy of the chain reaching full extension with the thought the trailer would be much more controllable if it hopped the hitch with the chains taking up the slack and the brakes being applied.
Any diagrams or pictures of your set up would be helpful.....
This is my first stop, I plan to play with google when I get time this evening.
Popular Reply
May 27, 2025, 06:57 PM
Strider250's Avatar
Strider250
The purpose of the breakaway switch is to activate the trailer brakes when the trailer completely disconnects from the tow vehicle, not just the hitch ball, to stop the trailer. The brakes are applied in full, i.e. locked up. You do not want that happening to you while the trailer is still attached, even if it is only by the safety chains. The cable must be longer than the safety chains that is the way the safety system is designed.
Old May 27, 2025 | 04:58 PM
charlie g's Avatar
charlie g
FTE Community Team
all my trailers the cable is longer , the tongue should drop onto the crossed chains then pull the cable tight to activate the brakes , so yes it's longer
Old May 27, 2025 | 05:05 PM
Phillbo's Avatar
Phillbo
But, if the cable is longer than the chains it will never reach a point where it will pull the pin. The chains will not allow it to reach that point if longer?????
Old May 27, 2025 | 05:45 PM
Old and soft's Avatar
Old and soft
Installed a eye bolt into an unused rear license plate bolt hole and clip it on there with a caribeener. Mine will definitely pull the pin before the weight rests on the safety chains. Gotta leave enough slack for tight turns.
Old May 27, 2025 | 06:57 PM
Strider250's Avatar
Strider250
Old May 27, 2025 | 07:07 PM
Strider250's Avatar
Strider250
Remember if the hitch fails and the safety chains catch the trailer tongue your truck still is connected to the trailer brakes through the electrical connection at the 7 pin plug. You can still control the trailer and bring it to a controlled stop using the truck brakes. The breakaway switch should not be activated for this scenario.
Old May 28, 2025 | 10:42 AM
acdii's Avatar
acdii
Hence the name Break Away. In addition you do not want it attached to the hitch either. If the hitch fails and comes out with the trailer still attached, the break away will not function. This mainly refers to 5th wheels, but can happen to receiver hitches too. I have seen where the guy looped it around the ball, only to have the shank fracture and come out with the trailer still attached to the ball, and he did NOT use chains! But I was only going a few miles does not excuse one from getting ticketed either.
You want the cable long enough so that you can fully work the trailer when hitched so that it doesn't get disconnected on a tight turn. I attach mine to one of the box links. For tag along I have a cable looped around the frame with one of those carabiner type loops to secure the break away to.
Old May 28, 2025 | 10:48 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Agree that it is supposed to be used when the trailer breaks completely away. I wouldn't want a full application if it just fell off the ball somehow. That would make things terrible, especially if traction was different from one side to the other. In a situation so dire that the trailer somehow falls off the hitch, having the trailer brakes suddenly go to full might finish it off and break it loose off of the tow vehicle. That'd be worse than leaving it connected by the safety chains.
Old May 29, 2025 | 11:21 PM
HRTKD's Avatar
HRTKD
The newer breakaway switches that come with a coiled cable are so short that I wouldn't be able to connect it to anything but the receiver hitch. I replaced the coiled cord that came with my trailer from the factory because it was so short that there was a lot of tension on it during normal operation. I think that was a 4' cable and I replaced it with a 6' cable. The 6' cable is certainly not hanging loose.
Old May 30, 2025 | 11:48 AM
Eman85's Avatar
Eman85
Does anyone think the chains are going to safely cradle the tongue of the trailer? That trailer is going to nose dive into the pavement grinding on the jack.
Old May 30, 2025 | 08:35 PM
Old and soft
I can see it now. Trailer falls off the ball. Your break away doesnt work because it's longer than the chains. First instinct is to slam on your brakes. Hitching/bumper takes out the jack (good luck putting it back on the ball that way), and pushes the propane tanks and battery thru the front wall of your travel trailer.
Old May 31, 2025 | 07:10 AM
shawnee1's Avatar
shawnee1
As stated in previous posts, the breakaway system is not intended to work just because the trailer has come off the ball. The trailer plug should still be connected (make sure it is long enough) so the trailer brakes will be activated when applying the truck's brakes. You don't want fully locked up trailer brakes in this situation as you will have no control over the outcome. Also, your first instinct in this situation should not be slamming on the brakes. This too will result in you losing control of the truck.
I had my dump trailer come off the ball once. My mistake. The trailer hitch was latched but I had recently lost the safety pin and thought "it's latched, it will be okay". Wrong.
I crossed over a bridge that had a good bump at both ends. I think the first bump popped the latch and the second bump popped the empty trailer off the ball. I applied the brakes gently and was able to move over onto the shoulder. I would not have been able to do this if the breakaway system had been activated. I have always used the safety pin after that event.
Old May 31, 2025 | 11:21 AM
meborder's Avatar
meborder
From experience, your first instinct should be to grab the trailer brakes to pull the chains tight then gently apply the vehicle brakes to slow down the whole rig. Doing this will result in a lot less damage to both vehicles.
As stated above, the breakaway is for a trailer that detached and broke the safety chains. The breakaway is to save other people from dying when your errant trailer decides its own path in life. It is for other people’s safety, not your convenience or use.
Old Jun 1, 2025 | 04:40 PM
acdii's Avatar
acdii
I have had a trailer pop off without brakes. The latch somehow got above the ball even though it was fully seated so it appeared to be latched. Hit the bridge abutment and off it went, cradled in the chains somewhat but also resting on the jack. I remove the shoe when travelling so it wound up scraping the pavement. Stopping got it to hit the license plate a couple times before it went under the truck with the hitch hitting the front of the V and damaging the aluminum plate. I hve since learned to reach under the ball and verify the latch is under the ball. I no longer rely on just jacking it up to see if its secured by lifting the truck with it, as it did that time. Hitting the bump dislodged it, or turning out onto the road did, but either way, I learned a lesson.
Old Jun 1, 2025 | 07:14 PM
FuzzFace2's Avatar
FuzzFace2
I dont know about you but I have yet to see a trailer that when sitting on the chains the jack was not already ripped off it's mount.
To test yours hook the chains up and lower the trailer down as far as it will go.
Did the chains hold the jack off the ground, I dont think so.
Dave -----
