New alternator issues
Old May 25, 2025 | 08:40 PM
KernalKlink88's Avatar
KernalKlink88
5th Gear
Hello again everyone!
I am working on rewiring my 1978 F250 with a harness from American Autowire. The new harness requires a one wire alternator. So I bought one from summit racing and got it installed several months ago now. Today I was getting back to work on it trying to button up the wiring and was just testing connections with a multimeter. I found out that I had a short somewhere, and discovered that it was the new alternator. So I took it out and the short is gone. The problem seems to be that the new one wire alternator is shorted to itself... I have continuity between the battery stud and the alternator body. And I have to believe that this is not correct, but before I call up summit and see if I can get an exchange or refund, I was wondering if someone here with more knowledge than me can confirm that this is incorrect? Or is there something else that I am doing wrong?
Thanks
Old May 25, 2025 | 11:55 PM
KernalKlink88
5th Gear
I took the alternator apart and was testing components, and in doing so I learned what a bridge rectifier is, and now understand that the alternator is most likely fine and behaving as it should. I feel like my ignorance just caused me to waste hours of my day. At least I learned something!
But I still have a question about it...
With the battery removed from the truck (and the alternator re-installed) if I test across the battery cables, it looks like I have a short, but only in one direction. The question: how will this not drain the battery?
Old May 26, 2025 | 12:21 AM
tbear853's Avatar
tbear853
Alternators generate AC voltage, rectifiers get it to DC.
Long ago, generators in cars and trucks generated DC voltage.
Voltage regulators do that thing they do.
Old May 26, 2025 | 09:21 AM
beartracks's Avatar
beartracks
The one wire alternator (all of them I beleive) has hot on the stud full time. the one wire is switch hot and enables it to charge. One wire alternators sometimes wont charge at low speed and may need a blip of the gas to initiate the charging.
Old May 26, 2025 | 09:38 AM
dlburch's Avatar
dlburch
if you have a short, it will measure the same resistance regardless of the meter polarity. A bridge rectifier is made up of diodes...diodes pass current in only one direction... :-)
JimSyg
May 26, 2022 10:55 AM
Nixoninc
Jun 23, 2021 05:13 PM
jbolty
May 30, 2019 05:25 AM
roller_steve
Oct 17, 2008 10:57 PM
skyhawk1
1997 - 2003 F150
Jun 18, 2006 06:16 PM
