Sponsored by: Real Truck
Differential or Transfer case?
Old May 25, 2025 | 08:23 PM
Tampadoc's Avatar
Tampadoc
1st Gear
Either my differential or my transfer case is going out and I can't tell which. Getting the telltale "clunk" and vibration and hum at certain speeds. What's a good way to diagnose which is going?
Old May 25, 2025 | 08:48 PM
aquanaut20's Avatar
aquanaut20
Either use a ChassisEar, or get it up on stands and use a stethoscope..
Old May 30, 2025 | 07:54 AM
Vintage Chief's Avatar
Vintage Chief
Cause for the telltale "clunk" is the propeller shaft splines need to be greased.
Old May 30, 2025 | 10:56 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I would agree with this, unless it has already been addressed and isn't changing the sound.
To OP - check your fluids before you presume something is going out. Make sure you aren't low, make sure there's no excessive metal shavings in the fluids, etc.
Old May 30, 2025 | 11:33 AM
stephen.osborne1's Avatar
stephen.osborne1
I'd check u joints as well...
Old May 30, 2025 | 01:38 PM
Vintage Chief
If it's a "clunk", it begins gradually over several weeks to a month - gets a little progressively worse, but quite noticeable when accelerating from a stop. I've re-greased the splines twice in 200K miles. This time I also did a center carrier bearing R&R.
Propeller Shaft Center Carrier Bearing
cryptonik420
Dec 3, 2002 12:57 PM
sparky
Jan 14, 2000 07:07 PM
