92 Explorer column gear shifter
Old Dec 5, 2003 | 03:17 PM
jdbrav's Avatar
jdbrav
Question 92 Explorer column gear shifter
I have problem with gear shifter. All started at once. Park is now reverse, and OD is slipping into first. I am assuming there is something wore out in the column shifter but have never dealt with this at all. Can't star truck either... can't get into park. Don't want to pay tow truck and mechanic need advice. Thanks in advance. Jason
Old Dec 5, 2003 | 04:03 PM
Opera House Works's Avatar
Opera House Works
I'd look at the transmission
where the cable sheath mounts. If the problem isn't obvious, then it is time for a tow.
Old Dec 5, 2003 | 06:35 PM
golfboy17's Avatar
golfboy17
Pull the pan and filter off the tranny, if the fluid is black with metal shavings your tranny is going, if the fluid is red its ok, something with the colum shifter or linkage that goes to the tranny
Old Dec 6, 2003 | 01:51 PM
jdbrav's Avatar
jdbrav
Pretty sure its in the linkage. Tranny's only few months old. Thanks
