Sponsored by: Real Truck
Electrical - Fan Control
Old May 11, 2025 | 11:39 AM
Ron Serling's Avatar
Ron Serling
Good morning,
I have a 99 S.D. for 20 years now and I have had a problem with the resistor pack on the heater control burning out now for the past few years. I have replaced it 4 times in the last three years and the blower motor is also new but the resistor pak keeps burning out and I only have high speed on my blower. Question is there anything anyone can advise me on what may also need to be replaced that can be causing the resistor to burn out?? Any help on this issue would be appreciated. Thanks
Old May 11, 2025 | 02:26 PM
Don Ridley's Avatar
Don Ridley
The fan speed control resistor pack is a simple device and there are no heavy duty versions as far as I know. The resistors drop voltage so the motor will run slower. A lot of current flows through the resistors and they get very hot. The flow of air though the HVAC plenum is supposed to keep the resistors cool enough so they don't burn out.
Are you using OEM resistor packs? Auto parts store and Amazon units may be the problem. Otherwise, make sure there is not a restriction in the plenum where the resistor pack is mounted (It would have to be something weird..maybe mouse nest material etc.). I would hot-wire the blower without the resistor pack installed to verify the air flow.
A fan motor that is drawing too much current can damage the resistor pack. But a new blower should eliminate this possibility. Also, check the terminals and connections in the plug. They can overheat and cause problems.
mikeg008
Sep 29, 2023 09:15 AM
HotdoGCruiser240
2009 - 2014 F150
Apr 6, 2017 03:14 PM
snoschu
Sep 2, 2009 07:55 PM
docdonnyb
Mar 10, 2006 06:45 PM
Yeti
Oct 28, 2002 11:09 PM
