Cracked front rotor
Old Dec 5, 2003 | 02:09 PM
seagull369's Avatar
seagull369
Cracked front rotor
Hi. I have a 94 Mazda B4000 4wd, which has a crack in the passenger side rotor. There didnt seem to be much problem with it until recently. Now when I ride down the road I get this annoying clicking noise which seems to be coming from that side. When I lightly apply the brakes, the noise goes away. I imagine whats happening is the pads are clanking against the crack at every revolution of the rotor which is causing the noise.
If my theroy on the clicking is correct, I was thinking of taking a dremel with a grinding bit to the crack to indent it somewhat so the pads dont contact the crack thereby elimintaing the noise. I just wanted to do this quick fix until springtime where itll be warmer out to change the whole rotor.
So what do you guys think? Crack causing the noise? Grinding down rotor relatively safe? One thing that makes me hesitant in replacing the rotor now is that the 4wd complicates rotor removal and I dont want to be rushing things now when its cold out.
Appeciate any thoughts.
Old Dec 5, 2003 | 02:45 PM
xvan053's Avatar
xvan053
Your front brakes are where most of your stopping power is. If it were me, I wouldn't mickey-mouse my front brakes just to save a few $$$ when they could save my life in an emergency.
I am curious as to how the rotor cracked? Was there a brake job done on this truck recently?
Old Dec 5, 2003 | 03:36 PM
Ken00's Avatar
Ken00
Replace it ASAP.
Old Dec 5, 2003 | 04:00 PM
hreed's Avatar
hreed
I'd replace it immediately! It's a lot colder 6 feet under and that's where you might end up if the rotor really is cracked.
Old Dec 5, 2003 | 08:21 PM
seagull369's Avatar
seagull369
Beats the heck outta me. The truck came that way when I bought it.
Im gonna give the grinding a go. See you on the other side if it doesnt work
Old Dec 5, 2003 | 08:45 PM
tonyford's Avatar
tonyford
Hail Mary full of Grace!
One emergency stop and the truck is going to pull towards the drivers side like a bat out of $#@% when the passenger side rotor blows apart. The intense heat generated from an emergency stop will do that. I have heard of rotors blowing out that had NO cracks in them, that is how thin they make them today. Every brake job I have had done so far (2) new rotors ALWAYS have been included in the job. Ford is notorious for making undersized braking systems in their vehicles, especially Rangers.
Do yourself a favor and any passengers that might be in your truck, get new rotors for the front brakes, and of course new pads.
THE LIFE YOU SAVE MAY BE YOUR OWN!
Old Dec 5, 2003 | 10:03 PM
jessfactor's Avatar
jessfactor
front rotors are pretty cheap and surprisingly easy to replace. i did it on my dad's 97 f150 for about 100 bucks. yours should be cheaper cause the disks are smaller. i recommend the haynes manual if u decide to do it. i personally wouldn't drive the vehicle w/a cracked rotor. if u care about your truck and more importantly your life fix it, southern engineering doesn't work w/brakes. -jesse
p.s. if u do get into a jam just remember: your parking brake controlls your rear brakes. if u jam on the brakes and something blows up just let off and ease the parking brake in.
Old Dec 5, 2003 | 10:31 PM
tonyford's Avatar
tonyford
Cheap?
I don't know about cheap. For a '97 Ranger the front rotors were $99 each installed. My mechanic only uses the best, and they are not made by Ford. I can't think of the manufacturer, all I know is it starts with a "W". Someone help me out. I am going to go nuts until I remember the name. They make more than just rotors I think, a full line of after market parts.
Old Dec 5, 2003 | 10:36 PM
jessfactor's Avatar
jessfactor
i ment 100 dollars for both ($50 each) for just the materials. they're easy to install. did it myself w/no experience.
Old Dec 6, 2003 | 12:36 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Suffer in the cold and replace it. They are not that expensive and they are pretty easy to install, even with the 4X4. Besides, should you get in a wreck and some insurance investigator sees that rotor, you will have some more problems on your hands in the event that you're at fault and someone else gets hurt. Unless you take certain actions, that crack will probably grow and increase the chance of rotor failure. I'm not gonna talk about how to take that certain action either.
Old Dec 6, 2003 | 07:20 AM
skoomer1's Avatar
skoomer1
I had a 95 ranger. The rotors had cracked on me also. Replace them suckers. It's not a tough job or an expensive fix (when you weigh out the safety issues).
Old Dec 6, 2003 | 07:33 AM
Bikeitswift's Avatar
Bikeitswift
Replace, Replace, Replace!!
A new rotor is only about $50.00. Your micky-mousing it with a Dremel is akin to trying to figure a way to keep adding air to a tire with a leak in it as you go down the road. I'd hesitate to drive it even down to pick up the part! If you are poor, get a used one at a junk yard, but replace that rotor! You can smugly drive on to the here after, I just don't want you to take one of us out in the deal!
Old Dec 6, 2003 | 12:56 PM
kevinswart's Avatar
kevinswart
Why would you mess around with a $40 part that could save your life or someone elses? Replace the rotor
