Oil filter
Old May 9, 2025 | 06:47 AM
Daniel Yosef's Avatar
Daniel Yosef
Oil filter
Hey guys. My 67 has the 352
i don’t have clearance to put fl-1a . Is it possible or any of you run the FL-400s?
Old May 9, 2025 | 02:02 PM
fe390pc's Avatar
fe390pc
Try the FL300a, I think that's the shorter version.
Old May 11, 2025 | 12:26 PM
davelj's Avatar
davelj
Napa 1068 or Wix 51068 is a shorter version. You can also get a swivel filter mount to point the filter somewhere with more room.
https://www.amazon.com/M-6880-B50-Adapter-Compatible-1965-1995-1966-1977/dp/B0D5VCBN3L?th=1&psc=1
Old May 20, 2025 | 07:12 PM
JEFFFAFA's Avatar
JEFFFAFA
I haven't but the FL300 is the shorter version. Ford had to come up with it for a 302 75/78 Mustang II .
Old May 21, 2025 | 08:44 AM
351Cleveland C4's Avatar
351Cleveland C4
Why is there not room for the FL-1A size filter? That's stock equipment. It should fit fine.
Old May 22, 2025 | 11:03 PM
52 Merc's Avatar
52 Merc
I wondered that myself. Curious what is in the way that the stock, original filter no longer fits.
The Motorcraft FL300 was used on 302/5.0's Fox bodies and all the way to 1995 and the end of sbf Mustang production and is a shorter version of the FL1A. I have a leftover in my cabinet from my Mustang days over 20 years ago. It would be a shorter, direct replacement for the stock filter if necessary.
Old May 23, 2025 | 05:38 AM
davelj's Avatar
davelj
FE engines used several different oil filter housings. It is a separate piece, unlike a small block where the filter mounting is part of the block. The housings put the filter different angles to fit the different chassis used over the years. It sounds like the OP has a car style housing.
Google FE oil filter mount
Daniel Yosef
Mar 22, 2025 10:10 AM
ClarkM
EcoBoost (all engine sizes)
Apr 29, 2017 09:58 PM
myexpo02
18
Jan 16, 2008 10:00 AM
F-250 diesel
2004 - 2008 F150
32
Feb 8, 2007 10:12 PM
numocystic_10
Oil & Lubrication
42
Jul 12, 2006 11:34 AM
