Help
Old Apr 28, 2025 | 03:38 PM
Dannydee's Avatar
Dannydee
5th Gear
Help
So I have a 2011 f350 super duty 6.2 liter with multiple misfires on cylinder 678 and I've recently changed all the coils wires and plugs... I've checked all the valve springs bc I thought it was a broken valve spring due to hearing some engine noise that I never heard before... It all started with hitting a rock with my cat on the driver's side cat and it became plugged and caused the exhaust manifold to start leaking so I hollowed it out but the multiple misfire is still there and the check engine light flashes and the codes I get are misfires on the 3 cylinders mentioned.... The engine noise is new as I've never had engine noise before.... I normally tow a huge tool trailer everyday with it and it currently has 179,000 miles on it... Never had any issues prior to the issues I'm having now... The truck fires right up and runs but smokes pretty good but it's not an oil burning smell, it's like a mix between oil and unburnt fuel smell... I'm lost on what the cause of this is and any insight would be greatly appreciated if anyone has any ideas on what this could be... I've had both valve pans off and checked the valve springs and looked at the timing chains and everything looked good to me... IDK much about the vvt things and don't know if they could cause this or not, the diesel sound at idle has me concerned as I've never heard any noise like that before other than the injector noise... I've checked the injectors and switched them around and the problem stayed in the same place... Any insight would be very appreciated bc I'm at my wits end with this truck... It's been the most reliable vehicle I've had and I wish I could figure it out
Old Apr 28, 2025 | 05:08 PM
charlie g's Avatar
charlie g
FTE Community Team
welcome to the site, i made a thread for you here https://www.ford-trucks.com/forums/1...lp-needed.html to help you better,
Old May 5, 2025 | 03:30 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I responded to the thread that @charlie g made over in the 1999 - 2016 Super Duty forum.
It looks like a duplicate post ended up in someone else's unrelated thread for some reason, and it received a response similar to mine.
Welcome aboard!
EYUPPER
Jul 23, 2024 08:30 PM
birdie94
New Member Introductions
Jun 30, 2014 11:35 AM
KevinGnWV
Apr 25, 2011 02:17 PM
brian ski
Feb 7, 2008 01:08 AM
