Drip rail
Old Apr 25, 2025 | 08:45 AM
canohb's Avatar
canohb
4th Gear
Drip rail
Does anyone know where I can find part D3TZ-1051704-D ?
Old Apr 25, 2025 | 09:14 AM
tbear853's Avatar
tbear853
Snap on drip rail bright trim maybe? LMC has or had them, as well as Auto Krafters. Likely Dennis Carpenter too, I expect Ebay too.
Old Apr 25, 2025 | 12:26 PM
canohb's Avatar
canohb
4th Gear
Look for the rear left sheet metal drip piece.
Old Apr 25, 2025 | 10:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 are you looking for the snap on trim piece or the actual steel drip rail? As in a drip rail repair patch panel?
DC for the trim for sure.
LMC for patch panels of the actual drip rail. https://www.lmctruck.com/body-compon...l-patch-panels
Old Apr 26, 2025 | 05:23 AM
46Whizzer's Avatar
46Whizzer
Are you referring to the (semi) vertical section behind the door? I haven't seen that one offered by anyone yet. You will likely either need to make something or source a piece from a donor cab if that is what you are needing.
buck27
May 20, 2024 10:16 PM
Mr. Rogers
Dec 4, 2017 02:10 PM
bb65f1004x4
Jan 1, 2014 11:00 PM
Redmanbob
Jan 10, 2010 04:31 PM
fordtruckn
Aug 13, 2006 09:56 AM
