You say, " gets fuel to injectors and turns over but wont run".
Do you mean, will crank but will not start? Or, will start but dies out?? You need three things for the engine to fire off, Spark, fuel and air. Have you tried the 50/50 test? Spray some starting fluid in the intake and crank, if it will not fire you are missing spark, if it fires up and dies out, you have a fuel delivery issue.
You need 35-40 psi of fuel pressure with Key on, engine off.
