Brake line routing
I have a question about brake line routing on a 56 f100...my friend is in the process of restoring the trunk...and just hasn't had the time to do it..so he's given it to me to finish...but the problem I have...its been given to me in boxes...and if I was the one that did the tear down...I would be able to start the resembley myself...so now I have one giant puzzle to figure out...my question is...where dose the front brake lines run? Do they come through the frame? Is there a specific hole they go through? Because I have a completely blank frame...with no mounting points from front to rear for the brake lines...thank you in advance for your help...
Glenn
Are you going for "factory" restoration and want to keep it all exactly as it was? If so I don't think I can help much. However:
Are you keeping the front drum brakes or switching to front disk? The only real upgrade I have done to the truck was a replacing front drums with front discs. Things happen way too fast on the road today and I wanted the benefit of the reduced stopping distance and margin of safety.
If you are going to front disc then you are changing your master cylinder and adding a proportioning valve along with slightly different fitment of the brake hoses. The kit ibises mounts the master cylinder and booster under the cab.
So for the front drivers side it is just straight shot to the wheel with some appropriate bends to connect the fittings.
For the passenger side I ran the lines through the big bracket that supports the clutch and brake arms and then made a turn and followed the contour of the crossmember back both the passenger side and the straight shot to the wheel again with the appropriate bends to connect the fittings.
intently bent the lines to conform with the shape of the from rails.
I haven't quite figured out how to secure the yet but there are 2 holes on the crossmember for retaing clips and I still need to figure out which existing holes in the frame will use to hold the line.
Even if you are planning to keep it stock you should probably update to a dual reservoir master cylinder.
The rear line is straight shot back and I just hand bent the lines to conform to the differential and line up with junction block. It's not a perfectionist install but it will get the job done and look decent.
We are going with front disc brakes...but im trying to keep it as close to original as possible...the truck came to me completely disassembled...so im at a loss to where the lines go...if someone had pictures of the front brake lines...that would help greatly
I don't know if the '56 is the same. What I don't have any information on is how the soft lines were connected to the hard lines. What bracket was used and where....I would love to know that myself!
Excerpt of the illustration:
For both the F-100 and F-250, the hard line to the rear terminated at the 59T-2073-B bracket which uses a 20389-S8 3/8"-24x1" bolt and 34370-S8 3/8-24 locknut to mount the side member. The hose is held into the bracket with the 78-2078-A clip. The hose freely runs to the distribution block mounted on the axle... On the F-100, the distribution block is mounted via the axle vent, and the F-250, via a bolt. The distribution block and hoses differ between the F-100 and the F-250 you guys have. There is also the hard line details (OD and lengths) that can be found in the brake line chart in some the catalogs.
Thank you
Master cylinder
Front driver side line
Front line crossover on frame
Front passenger side line
Flex connection frame to rear axle
Distribution block on rear axle
Passenger side rear line
