TPMS Valve Stem Repairable?
Old Apr 18, 2025 | 03:10 PM
Squanto's Avatar
Squanto
Leaving a park today I heard a hiss from my LR tire. I figured it was a tire plug leaking. I had enough air to get home without the tire bulging. The plug, however, was intact. The leak was on the valve stem and given the neighborhood I was in I'm not sure if someone didn't kick it.
Anyway, is the stem part repair able or do I need to get a new one? If it's replace only, does anyone have a part #?
Old Apr 18, 2025 | 04:17 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
What "repair" would you do to it?
The core is replaceable, same as a regular valve stem.
But, if someone kicked it, then it probably broke the rubber and it is no good anymore, and would need to be replaced.
You wouldn't need to replace the sensor, just the stem, any tire store can do it and would have the valve stem on hand.
Old Apr 18, 2025 | 04:22 PM
Squanto's Avatar
Squanto
That's what I mean. I'd rather not replace whole sensor/stem unit. Glad to know the sensor can be moved to a new stem.
Old Apr 18, 2025 | 06:45 PM
Joe T's Avatar
Joe T
Yeah you can attach your tpms to a new valve stem. Get the Ford one so it matches the others.
Old Apr 18, 2025 | 07:02 PM
Squanto's Avatar
Squanto
So, I'm needing new tires anyway and had already called Discount Tire yesterday. I called them today and they said they could move the sensor. I asked if I ordered new tires would they take care of the valve stem. Apparently, the nut holding the sensor had corroded so it broke trying to move it. They gave me a new sensor but after they put it on it wouldn't work. Anyway, new tires in tomorrow so they'll fix it then.
Old Apr 19, 2025 | 09:10 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
I have had discounti tire rebuild/replace the TPMS valve stem as a routine when I bought tires. It doesn't happen all the time. I have not asked about it
BigBlue2
37
Dec 16, 2023 09:27 PM
sherpa
2009 - 2014 F150
Dec 30, 2019 01:43 PM
hi-jacker
Dec 6, 2014 07:53 AM
fordinmudd
Offroad & 4x4
Apr 17, 2007 01:31 PM
knucklehead11
Bronco II
Aug 12, 2003 06:58 PM
