Sponsored by: Auxito
Help-Crank, NO start
Old Apr 18, 2025 | 12:39 PM
Bill Whit's Avatar
Bill Whit
2nd Gear
Got a 2002 F150, 4.6 that has a crank, no start problem. Started with a PATS problem so I had the PATS delete done on the ECM. I still had no start. Checked for spark-no spark. Changed out the Crank sensor and it started right up. Drove around the block, stopped the engine , and now it won't start again. Still no spark. I checked for continuity from the ECM plug to the CKP connector. Meter shows a open on both sides. According to the wiring diagram, the wiring goes through 2 connectors, C4202 and C120. Can't find them anywhere. Does anybody have a location for these connectors ?? TIA !
Old Apr 18, 2025 | 01:24 PM
BareBonesXL's Avatar
BareBonesXL
Thought my 2003 might be similar but it's not. It shows only one 42 pin connector, C133, back in the vicinity of the PCM. Rear, right hand side. Might be a clue for you.
And my connector numbers only go up to 4141.
Old Apr 18, 2025 | 03:00 PM
Bill Whit's Avatar
Bill Whit
2nd Gear
did a little more testing. Both pins 21 & 22 (On ecm plug) show high resistance grounds. Nothing on the CKP connector to ground. TRied tracing the CKP connector lead but it is tied in solidly to the block.
ed60
16
Jan 26, 2025 06:55 PM
Bweston232
1997 - 2003 F150
Jun 6, 2019 06:02 PM
randy89
Jun 28, 2015 10:12 AM
Trailblazed
21
Sep 28, 2011 02:07 PM
seanmac
1997 - 2003 F150
Mar 1, 2011 01:03 PM
