2025 Slushbox Operation Temperature
Old Apr 19, 2025 | 04:13 PM
  #31
jarrsong's Avatar
jarrsong
Originally Posted by willynilly
who complaining ? im just saying most trans including the ram powerline run 170 unloaded. fords run 215. significantly higher temps
yeah, that’s the bottom line. I do stand corrected. I thought the bigger one was code developed like the smaller units. If you want to reduce your trans temp lock out ninth and 10th at lower speeds.
Old Apr 19, 2025 | 04:15 PM
  #32
PSDlongbox's Avatar
PSDlongbox
right, but who cares? If ZF engineered their trans and trans fluid to work together at 170F than comparing that to Ford 10R140 that was engineered to run at 215F is like comparing apples and oranges
Old Apr 19, 2025 | 04:20 PM
  #33
OBS460's Avatar
OBS460
ULV is fine running 215F ALL the time without causing any damage.
Old Apr 19, 2025 | 04:21 PM
  #34
jarrsong's Avatar
jarrsong
because heat kills fluid. That’s true today like it was three generations ago. And I know about new synthetic and stuff that have higher heat capability. Sounds like the Ford runs hotter for emissions reasons. That’s not a good reason to run it hotter.
  #35
willynilly's Avatar
willynilly
makes a guy wonder what they were thinking. 1mpg better fuel mileage ? 2hp more ?
Old Apr 19, 2025 | 04:22 PM
  #36
jarrsong's Avatar
jarrsong
How it works. Needless complexity. The 10R140 uses a coolant control valve in its transmission fluid cooling system, which is attached to the coolant return hose. This valve, controlled by the PCM (Powertrain Control Module), restricts coolant flow through the warmer when the fluid is cold to help it warm up faster. Once the fluid reaches a predetermined temperature—around 220°F according to user reports—the PCM signals the valve to open, allowing coolant to flow and cool the fluid, maintaining an operating range of about 208-221°F. This design prioritizes fuel economy by allowing the transmission to run hotter, as higher temperatures reduce fluid viscosity and parasitic drag, though it has raised concerns among some owners about long-term durability.
Old Apr 19, 2025 | 04:28 PM
  #37
PSDlongbox's Avatar
PSDlongbox
if only they had teams of engineers designing hardware and lubricants to work in harmony. Maybe one day. Thats the dream.
Old Apr 19, 2025 | 04:29 PM
  #38
jarrsong's Avatar
jarrsong
if you ever really wanna learn about fluids and viscosity, look up the motor oil geek on YouTube. Prepared to be amazed.
Old Apr 19, 2025 | 04:31 PM
  #39
jarrsong's Avatar
jarrsong
and honestly, I think the part you’re missing is all they need to get you is out of the warranty period.
Old Apr 19, 2025 | 04:34 PM
  #40
willynilly's Avatar
willynilly
heres a snipit from a article on the ford 10spd. full article below. also explains why it shifts so clunky
Additionally, the OEM stator, the component responsible for controlling stall speed, is absurdly high stall. This is because stators have a notable impact on idling emissions, something the EPA is deeply concerned about. To the benefit of our consumer, we don't give a **** about the EPA. Our priority is on reliability, functionality and driving dynamics; things relevant to you as the owner of the vehicle.
Lastly, and as a collateral effect of the stator, the OEM converter escalates average operating temperature (AOT) by a considerable margin because the large allowable difference in speed between the motor side and the input shaft side of the converter is so immense. This generates huge amounts of thermokinetic energy, a chemical reaction producing heat. Heat is a silent killer in the transmission world, and detracts from the longevity of any transmission
https://nextgendiesel.com/blogs/tran...lems-solutions
Old Apr 19, 2025 | 04:57 PM
  #41
jarrsong's Avatar
jarrsong
Great article confirming most of what I said. I know you’ll have clowns on here that say they have a fleet of 50 of them towing 50,000 pounds regularly which technically makes you an idiot. Take care of these transmissions. They are not cheap and Ford only needs to get you out of the warranty. That is the ultimate goal.The dealer was the one that cut the check for the warranty one that our family shop bulletproofed. Full disclosure I don’t work in the shop anymore so much of this. I’m getting secondhand now. But in high school and growing up I have R&R’d hundreds and hundreds and hundreds of transmissions. I know what transmissions are **** and which ones are good probably forgetting more information than most people know. But always learning like now. I’m thinking defeating that thermostat device on our transmissions.
Old Apr 19, 2025 | 05:05 PM
  #42
jarrsong's Avatar
jarrsong
Originally Posted by 1olddogtwo
I've got about 35 10 speeds in my Fleet, three of those transmissions normally see weights of 50,000 lb. Zero issues.
what model trucks are they?
Old Apr 19, 2025 | 05:24 PM
  #43
1olddogtwo's Avatar
1olddogtwo
This idiot clown has 250 thru 550 with 10 speeds.
I essentially run a hotshot type of a fleet, but what do I know.
Old Apr 19, 2025 | 05:25 PM
  #44
jarrsong's Avatar
jarrsong
This clown has 250 thru 550 with 10 speeds.
Lolol. Just slightly overloaded. Lol hopefully they’re off highway but something tells me they’re not.
Old Apr 19, 2025 | 05:55 PM
  #45
PSDlongbox's Avatar
PSDlongbox
I'm not saying the 10R140 is a fantastic transmission, or a garbage one. My contention is that arguing trans temp guidelines that are not specific to the transmission and fluid is an act in frivolity. It is 100% irrelevant what any other transmission should/would/could run. The 10R140 with Mercon ULV is designed by Ford to run 200-215F unladen and is within Ford spec for temperatures much higher. This is really the only "scientific" information we have. Stating that you need to run your Ford 10R140 at -75F for optimal service life is anecdotal. Zero empirical evidence as been presented to the contrary.
