Throw out bearing question
Old Apr 10, 2025 | 10:13 AM
Will1997f350cclbdually's Avatar
4wd Low
So I recently installed a new clutch kit and the brand new throw out bearing makes noise when the clutch is engaged but not when you depress the pedal, I reused the old fork and master cylinder so before I go tearing the trans out again are there any problems I should look for that may or may not fix it. And before you ask yes the throw out bearing is in the right way and yes I greased it.
Old Apr 10, 2025 | 12:59 PM
knottyrope's Avatar
knottyrope
Does it make noise in N?
Can you feel the fork vibrate?
Old Apr 10, 2025 | 01:24 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Single mass fly or dual?
Single make far more noise
Old Apr 10, 2025 | 01:50 PM
4wd Low
single mass flywheel but it’s when it’s in neutral and it was a single mass that came out
Old Apr 10, 2025 | 02:00 PM
4wd Low
gotta check that when I get home and yes it is making noise in N
Old Apr 10, 2025 | 04:31 PM
4wd Low
Noise in video
Old Apr 10, 2025 | 04:34 PM
4wd Low
Fork is vibrating
Old Apr 10, 2025 | 04:37 PM
96SD's Avatar
96SD
Sounds like gear rollover to me.
Old Apr 10, 2025 | 04:52 PM
4wd Low
I was thinking that but it’s a little aggressive for gear rollover unless the clutch that came out of it which had all the springs loose was hiding it from me, I’ve driven it from Ny to Texas and Tennessee before I did this and it was never quite so noisy, however it did make a lot of noise in reverse prior to changing the clutch and now it’s really quiet so idk.
Old Apr 10, 2025 | 05:37 PM
96SD's Avatar
96SD
Good fluid in trans? Some people over fill and say it helps with the noise. As a inherently unlucky person I see It like winning the lotto that my rollover noise is very little. I think its different noises for different trans/clutch setups. I am also not near a mechanic so if you were to 100% ignore everything I said or say in the future, your life my be better for it.
Old Apr 10, 2025 | 06:43 PM
4wd Low
fresh fluid in it and I’m not ignoring anything you say I’m open to all suggestions lol
Old Apr 10, 2025 | 08:27 PM
97-psd's Avatar
97-psd
Did you overfill it? That can help reduce some of the noise.
Old Apr 11, 2025 | 05:15 AM
4wd Low
didn’t overfill it yet thinking I’m gonna try that or try a slightly heavier oil than atf or maybe add some Lucas hd oil stabilizer?
Old Apr 11, 2025 | 08:15 AM
Hit Man X's Avatar
Hit Man X
It is a big medium duty trans, it will be loud.
Five quarts total cap is what most if us do, filled via the top. These spec ATF, I have Redline D4 in mine.
Old Apr 11, 2025 | 08:17 AM
4wd Low
I’ll give it a shot see what it does, gotta be easier than pulling the tranny back out lol
