Body Swaping
Old Apr 9, 2025 | 07:21 AM
grim_reaper23's Avatar
grim_reaper23
1st Gear
Body Swaping
I have a 93 f150 with the 300 inline 6 5 speed 2wd, I want to make it 4wd, but after researching it, I’ve come to the conclusion it’ll be easier to just swap my body and motor onto a different frame and tranny, can I swap my body onto a brick nose frame without any issues or will I have to do fabricating?
Old Apr 10, 2025 | 10:39 AM
Rusty Bucket Ohio's Avatar
Rusty Bucket Ohio
From what I understand the cab and everything will work fine but the radiator support across the front will need to be replaced if you are going to use the newer front end but if you are going to only replace the cab it will swap … wiring harness needs to change also … I haven’t done it but researched because I considered doing it myself …
Tmarkh
Aug 17, 2017 04:59 AM
Powerstrokin_350
Jul 19, 2010 08:09 PM
Madathlon
Mar 10, 2006 03:46 AM
billbain
Nov 6, 2001 12:09 PM
fyrfytr
May 11, 2001 06:06 PM
