2017 Powerstroke Do It All Build
Overall it’s been an extremely capable rig that has been great to work out of, travel in, and beat on. The power/suspension combo is about perfect for what I do.
Here is an overview of the build:
Performance
- SPE Emperor S370 Ball Bearing Turbo Kit
- Maryland Performance Trans
- North Coast Diesel Performance Converter and Trans tuning
- CPX Pump
- Tuned
- S&B intake
- 5” exhaust
Suspension/Wheels
- Carli 5.5” Backcountry kit
- Carli Swaybar and Endlinks
- Apex Chassis Steering Linkage
- Carli Track Bar
- airlift bags in cradles
- Method 704HD
- 37x13.5R17 Toyo RT Trails
- Full size matching spare in factory location
- Powerstop brakes
Exterior
- Fab Fours Premium bumpers front and rear
-Rocky Road rock sliders
- Rigid radiance scene lighting front, back and ditch.
- 4 Amazon special BD LP9’s up front. Use way more than I thought so budgeting for the real thing, but honestly these things are awesome for the money.
- Superwinch 18k winch / Factor 55
- Diamondback HD Cover
- UpTop bed rack for Diamondback
Stereo
- Kenwood Excelon XR-600 Amp w/ DSP
- Alpine 1000w amp
- Custom amp rack in factor location
- Morel Ultra Tempo front components and rear coaxial
- Alpine 10” slim box behind seat
- LMI Welding rear seat brackets - moved seat forward 2” and up 2.5”.
- Fully sound deadened truck
Power
- 200ah LiFePO6 house batteries
- Renogy nppt mounted to BuiltRight molle panel behind seat
- Solar on top of RTT
- Aftermarket inverter in factory location
- Retrofitted factory under seat storage to work with lift, and installed built in charging capability for drone, Milwaukee chargers, GoPro, etc.
- Starlink integrated to house batteries
Rack Setup
- UpTop Overland diamondback rack
- Freespirit Odyssey RTT
- Reign Outdoors 270 awning and shower stall
- Midnight Forest 8 gallon water tank with pump
- Badlands jack in Motobuilt mount
- Baja Designs scene lights with Kingpin tailgate light
- Rotopax fuel for diesel heater
- Starlink Mini up top
Overall this is about where it sits. There are a couple last changes I plan to make:
- I am looking to switch to a camper shell setup for something a little more usable for everyday needs, that I can then easily drop the RTT on to when needed. The lack of available headroom in the bed has been a problem in the past.
- Upgrade shock package from the Backcountry once they are worn out to either the Eventure or Dominator setup. The back country has been excellent for what I use the truck for now. It’s been a great balance of comfort with added capability. However, as I plan to push the truck more I would really like to increase the capability of the system. The eventure seems like an awesome system with a ton of functionality, but I will probably go to the dominator because it’s a more simple system and why not a 3” shock.
- I have always planned on putting compounds on this truck. I’m leaning towards the Maryland performance compound and piping kit. However, the turbo lag really isn’t as bad as I thought it would be, and may not want to add more complication to it.
- Larger fuel tank is definitely something I want to do, but with how much we wheel the truck, the lost clearance worries me. Looking for a solution and may end up fabricating my own.
- I want to swap the chinesium knockoffs for actual Baja Designs LP9’s as I use those lights a lot more than I thought I would. I am likely going to swap out some of the lights for better customization for different situations. Right now it’s basically all or nothing, which is great for job site lighting and campsites, but not so much for dusty trails or back roads.
- fix my no crank no start issue! Making a separate thread for this.
Thanks again everyone!
