302w vs 351w
Old Mar 31, 2025 | 11:16 AM
newtruckgiy's Avatar
newtruckgiy
3rd Gear
302w vs 351w
So I have just inherited my dads high school truck which was a 1979 f150 and I'm going to be rebuilding the truck but the 351 m that is in it is completely seised and so is the transmission so I want to throw in a 302w or 351w in it and I will probably be stroking the engines in the future so I want to know which engine I will get more power out of for a reasonably price
Old Mar 31, 2025 | 11:28 AM
4x4 Bart's Avatar
4x4 Bart
351w much better truck engine.
Old Mar 31, 2025 | 11:40 AM
tbear853's Avatar
tbear853
Are you sure the transmission is seized too? In any case, is no throwing either in. I understand the meaning, but neither is a straight swap.
Gonna be easier and require a lot less work if 4wd going back with a 351M or 400 base.
If 2wd, it'll be a bit of searching brackets, etc, but will be easier connecting a driveline.
Old Mar 31, 2025 | 12:22 PM
newtruckgiy
3rd Gear
Its 2wd and I'm sure that the transmission is seized
Old Mar 31, 2025 | 12:29 PM
newtruckgiy
3rd Gear
I got a 1984 4wd F150 frame I could put it on but I would still need to choose an engine for it
Old Mar 31, 2025 | 04:36 PM
Fleur de lis 82's Avatar
Fleur de lis 82
Both are popular engines, but there is no replacement for displacement in my opinion. Go for the 351W. I'd look for a later production roller block too, capable of a heck of a lot of power. I've got one sitting in the pile-O-crap waiting for a rebuild to got into the Platypus truck someday.
Motor mounts / tower for 2wd small block.
https://www.vintagetruckand4x4.com/product/fta-win/
If you do YouTube, look up Neomustangs. Guy does a lot 302 / 351w builds for fox bodies. Has a ton of useful information.
Old Mar 31, 2025 | 10:19 PM
atitagain4's Avatar
atitagain4
If I wanted cubic inches I would do a 460!! All day everyday!! They are making quality heads and stroker kits and good roller cams.
for a daily driver or a weekend cruiser I would do a factory roller 302! Cheap…parts galore…lighter weight/smaller package size in the engine bay. I would stroke it to a 331, AFR heads and a “rv” smaller duration/lift cam and you would be putting down 350+ hp…way more hp and TQ than any era OEM option for that truck.
I’ve built a few of them and they are strong little engine. The one in my mustang is about 460hp, revs to 6,500 and is almost to much for a 3,000 pound street car. The other one makes about 340hp but it has the power band way low for a bronco, still makes power all the way to 5,400.
Old Apr 1, 2025 | 10:26 AM
Old Guy F-250's Avatar
Old Guy F-250
Yea,,back in the day, what we called the 302 HI PO was quite the deal. Great race engine with high RPM and power.
Louiesant
Apr 14, 2025 05:49 PM
Krazy1
Feb 10, 2023 10:50 AM
Graffe
Apr 10, 2002 11:29 AM
lghtnin351
Oct 16, 2001 10:04 AM
