2 interesting tidbits
Old Mar 29, 2025 | 10:32 AM
atitagain4's Avatar
atitagain4
I finally did a leak down test on the in-line 300. Original engine with 143,000 miles.
all cylinders were between 10.5-12.5 percent leak down with the majority of the leakage going past the rings and out the crankcase / PCV opening. The only odd cylinder was #2 at 24 percent.
I have the timing set at 12 degrees. I recently rebuilt the YFA single barrel carb. To get the hieght vacuum and good idle I have to open the air/fuel multiple turns. With the curb idle screw almost backed all the way out it idles right at 720-40. Its runs and idles smooth and I could probably stand a nickel on end and it would stay. I just didn’t think that little one barrel would want that much air at idle….or maybe there isn’t enough fuel?
the engine has 17in vacuum at idle and a steady needle. I can see a slight rhythmic dip (maybe 1/2 in vacuum) at idle which is probably the #2 cylinder.
I am at almost 5,000 above sea level.
george kosht
Jul 31, 2019 02:47 PM
MeanGreen72
Jun 16, 2019 11:31 AM
DrZoom
30
Dec 15, 2015 07:11 AM
4x4 Bart
May 4, 2008 02:48 AM
ON1Fordteam
Jul 23, 2007 01:34 PM
