The truck is daughter #1's truck, 2021 F150, 2.7 turbo
not charging and I "think" it's an alternator.
Knowing I am extremely swamped she drove it to a shop, after a couple days of no contact she calls them.
They tell her they "think it's the alternator." They tell her they cannot get a "map of the wiring" for that truck and they also cannot buy an aftermarket alternator so they have to get one from Ford for $1000.00 and change, and it "might" take care other problem.
The truck had some wiring chewed by varmints last year, therefore the reference to wiring "map."
The quote is $1,300.00 alternator and labor.
I checked with O'Reily's and they can't get one, Twighlight Zone said they could order one from a vendor for $749.00 plus $8-$12. shipping depending on when you want it.
I can't believe a shop tells a customer that for $1,300. It "might" fix the problem?
If you get it started and voltage goes up when running it's not the alternator. And I doubt it is.
O'Reilly and AutoZone can check the battery and alternator both while still in the truck. I'd start there. Sure wouldn't pay someone $1300 for something that might not fix.
I neglected to add the reason "I think it's the alternator" is I had the battery charged and with the truck running it only reads battery voltage which slowly drops off after starting and running a high electronics use vehicle.
My digital voltmeter is pretty accurate. So I recommended to my daughter to take it off and have the alternator checked remote from truck. I guess this shop doesn't want to get that far and not have another one to install, tying up their bay?
Any thoughts? Thanks!
Yes....the system is controlled by the computers (multiple, sensors, etc.) and is a very, very complex system- short answer, it ain't like it used to be.... need to hook up a diagnostic siftware (Forscan, etc.) and really see what is going on............. which hasn't been done obviously
if it is the alternator rock auto parts show 3 from motorcraft for 600 and under, dom you know how the cable ends look? any signs of corrosion will stop the computer from working properly
Almost always on a newer Ford truck, it's going to be that battery itself. The OEM batteries are notorious for having a short life. I would retrieve the truck from the shop, or at least, since it's there, have them install a new quality battery so you don't get hit with a big diagnostic fee. It's going to need a new one anyway, as AGM batteries don't take well to being recharged.
If the problem occurs again, take it to an ASE certified, independent shop with a high online rating. One where they don't guess, and have proper Ford licensed diagnostic equipment.
