Rich running condition/other problems
Old Mar 24, 2025 | 11:11 AM
TrailerMan2503's Avatar
TrailerMan2503
8th Gear
Hey guys, I have a 351w with factory dish pistons and some unknown aftermarket aluminum heads. I am having an unfixable rich running condition. At least I think it’s rich.
I have an edelbrock avs2 800 cfm at the leanest jetting and metering package on the tuning chart and still have spark plugs that are trying to foul. There is a slight bit of oil on the outside ring of the plugs, nothing too crazy tho IMO.
I have heard that aluminum heads use longer reach spark plugs than factory, I am using factory plugs; could this be causing fuel to pool up on the plug?
Additionally I am running a 160 thermostat, could I need a hotter plug to burn off the fouling? Or should I try to run a higher thermostat to maybe mitigate the blow by?
sorry I know it’s a lot of info, but I am at an impasse! Thanks for any help you guys can give me!
Old Mar 24, 2025 | 11:32 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Need to figure out what heads, to get correct plug, stock cam?, how much timing before you get pinging, what made you think you need a 800cfm carb? prolly need to step down a few 100cfm's with a stock cam.
Old Mar 24, 2025 | 11:41 AM
TrailerMan2503
8th Gear
comp xe 274h flat tappet, 230 ish duration at .050 if I remember correctly. Lopes pretty good. Can’t find a thing on the heads. I used a mic to find the length to the end of the threads for the spark plug hole and it came out to 3/4 inch. Nervous to move to the longer plug because I’ve heard those consequences are much worse than running one too short. At wot I can run upwards of 40 degrees if I really wanted to without pinging, at part throttle however I was running into pinging around 2000 rpm. Hooked up vacuum advance and bump total timing down and that problem is not near as bad
Old Mar 24, 2025 | 11:49 AM
TrailerMan2503
8th Gear
also compression test came back healthy, within 5% on each cylinder
Old Mar 24, 2025 | 05:56 PM
cougrrcj's Avatar
cougrrcj
800cfm is waaaaay too big for a stock-ish 351W. Heck, I was running a 670cfm Holley Street Avenger on my mildly cammed (X4262H) 9.4:1 393W - That's another 13% bigger than the stock 351!- and it passed Ohio's emissions testing leaned out a bit (emissions tested at idle, and 2500rpm)! Oh, the headers were glowing red, but it passed. I daily-drove that car/engine for years, but stepped up to a 750cfm carb for racing with a self-imposed 5400rpm limit. Street manners were better with the 670.
Old Mar 25, 2025 | 11:28 AM
baddad457's Avatar
baddad457
An 800 cfm carb is WAY to big. As for the plugs, if they're not protruding into the chambers, then that will cause them to look as if the mixture is too rich. And your cam is much too big for your comp ratio. Post pictures of the heads. There should be at least a part number on them somewhere. Your engine would be happier with a smaller cam (like an EFI grind) and a smaller carb. Or just disconnect the secondaries on that carb and run it as a 2 bbl. It will flow a little more like that than a Holley 500 cfm 2 bbl does. A Holley 500 2 bbl is half of a 750 CFM 4 bbl.
Old Mar 25, 2025 | 08:43 PM
DaveMcLain's Avatar
DaveMcLain
Most aftermarket aluminum heads use gasketed plugs with a 3/4 thread like an Autolite 3924. If you're using the 3/8 thread plug then that puts it up inside of a hole and it will run poorly. Check that first.
I don't think I'd worry about the carburetor size very much. Carter carburetors are not rated at the same depression as a Holley so for the same cfm rating they are smaller by about 15% or so.
bruno2
Apr 6, 2014 08:37 PM
Jeff Olsen
2004 - 2008 F150
Dec 22, 2011 05:58 PM
DRM2004
2004 - 2008 F150
74
Feb 19, 2011 06:25 PM
UBRKIFX
Jul 10, 2009 12:06 AM
90F1505.0L
Dec 27, 2004 02:09 PM
