7.3 idi no start
Old Mar 21, 2025 | 07:34 PM
Slippin Jimmy's Avatar
Slippin Jimmy
6th Gear
7.3 idi no start
Hello I have a 1989 7.3 idi. Truck ran good for awhile but cannot get it started now. Excessive smoke when cranking. Here is what I have checked so far:
glow plugs are working properly
electronic fuel pump is working
fuel in and out of the injection pump
FSS is working properly
fuel at all injectors
no loss of coolant
any help would be greatly appreciated. Thank you in advance
Old Mar 21, 2025 | 08:08 PM
ihc1470's Avatar
ihc1470
Is it cranking at normal speed? If it is turning over slow it probably will never start. Measure battery voltage, should be around 12.6. If you do not see that voltage recharge batteries.
Old Mar 21, 2025 | 09:18 PM
Slippin Jimmy
6th Gear
Yes the batteries are good. Cranks pretty good in my opinion. Seems plenty fast enough.
Old Mar 21, 2025 | 09:29 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
How long ago was the truck running? Does the block heater work? If so, did you try plugging it in? Have you tried to see if it fires on starting fluid?
Old Mar 21, 2025 | 09:33 PM
Slippin Jimmy
6th Gear
Started it on ether about a week ago.
block heater currently doesnt work.
Old Mar 21, 2025 | 09:49 PM
FORDF250HDXLT
It doesn't start on the spray now? Why the spray then and not now? Because you just replaced the glow plugs? With what brand?
Old Mar 21, 2025 | 10:09 PM
Slippin Jimmy
6th Gear
It will start with spray but I would like to start it without the spray. Replaced glow plugs last year with OEM Motorcraft plugs.
Old Mar 21, 2025 | 10:17 PM
BigBlue2's Avatar
BigBlue2
If the glow plugs are operating shouldn't need starting fluid. Some caution to only use starting fluid if glow plugs are disabled as damage can occur to the plugs.
Excessive smoke and hard to start could be due to a loss of compression. Head gasket? Are you using any oil?
Could have fried the glow plugs with ether? Check them again.
Old Mar 21, 2025 | 10:24 PM
WCMtn1990's Avatar
WCMtn1990
I have to ask were the glow plugs purchased from a reputable source or were they from Ebay? There seem to be a fair amount of bogus 'Motorcraft' plugs out there.
Old Mar 22, 2025 | 08:26 PM
FORDF250HDXLT
Yeah, if it's starting on starting fluid, then the glow plugs are probably not working.
Old Mar 23, 2025 | 03:54 PM
Prototypemech's Avatar
Prototypemech
My IDI starts reliably down to about 14°f with Motorcraft zd-9 plugs. It doesn't get colder than 14°f, so I don't have any data below that.
Old Mar 26, 2025 | 05:38 PM
Slippin Jimmy
6th Gear
So I removed all the glow plugs and checked them. Reading between 1.0-1.2 ohms on all 8 plugs. Not sure what resistance reading a good plug should have. These are motorcraft ZD-9 plugs from the auto store.
Old Mar 27, 2025 | 11:51 AM
ihc1470's Avatar
ihc1470
Ohms law for amps is voltage divided by resistance. So lets say you have 10 volts to the glow plug system and you divide that by your 1.0 ohms resistance that gives you ten amps of current draw. A good plug draws around 20-22 amps. All 8 plugs will draw close to 200 amps if the system is working right. So I would say you have bad plugs. Go to an auto parts store and buy a 30-0-30 amp meter and test then using that. Look for that 20 amp draw.
Old Mar 27, 2025 | 12:11 PM
Slippin Jimmy
6th Gear
Thank you i will check this when i get home.
Old Mar 27, 2025 | 12:25 PM
BigBlue2's Avatar
BigBlue2
Don't forget to ohm your test leads first. And subtract that from the reading on the plug.
I have a new Motorcraft plug in my shop I'll go out and check it later and post what I measure. I always have tested with the bulb in situ.
