Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Ford 534/477/401
Old Mar 21, 2025 | 07:12 PM
Shh1966's Avatar
Shh1966
Trailering
Ford 534/477/401
Anyone know which engine this is. I can’t find any tags or the block stamp
Old Mar 21, 2025 | 07:47 PM
85e150's Avatar
85e150
Can't tell.
'76 was the last year of the 401, but the carb tag indicates a '69 revision and the heads have a 1970 revison, (D0TE) so it's older than '76 and could be any of them.
Looks like it's in a C series. Is there still a warranty card on the cab door? That's always a long shot as the engine could have been replaced.
These are hard to find parts for.
Old Mar 22, 2025 | 12:11 AM
Shh1966's Avatar
Shh1966
Trailering
Vin indicates 292 y block as it’s a 61 c600. Someone Definitely swapped the engine. Where is the casting number on these blocks. I ve searched all over and can’t seem to find it
Old Mar 22, 2025 | 12:37 AM
85e150's Avatar
85e150
Does the truck have 6 lug wheels?
Engine swap to that thing would be a chore.
Door swap without changing the warranty tag...pretty easy.
Old Mar 22, 2025 | 10:14 AM
Shh1966's Avatar
Shh1966
Trailering
Yes 6 lug wheels
Old Mar 23, 2025 | 12:29 AM
garygnu's Avatar
garygnu
have some one turn the engine over by hand ,and use a long zip tie to measure the stroke the piston travels .then you know what crank you have
Old Mar 23, 2025 | 12:54 AM
charlie g's Avatar
charlie g
FTE Community Team
mix of parts going by those casting numbers , B9 or 59 , C3 or 63, D0 or 70. please try to find a block number which may possibly be hidden by the starter
Old Mar 23, 2025 | 01:06 AM
Shh1966's Avatar
Shh1966
Trailering
I’ll search around the starter area again
Old Apr 7, 2025 | 01:41 PM
Shh1966's Avatar
Shh1966
Trailering
No luck finding a casting number on the block
Old Apr 7, 2025 | 01:53 PM
Shh1966's Avatar
Shh1966
Trailering
I’ll check the stroke with a zip tie. Also trying to identify this transmission. I need the clutch/flywheel cover piece as it is missing
Old Apr 7, 2025 | 02:13 PM
85e150's Avatar
85e150
Transmission is possibly/likely a Spicer 6352,
6352 is listed as Dana (Spicer) in the '64-'72 MPC as 6352, 6352A and 6352B, all 5 speed direct.
https://truckpartsinventory.com/part...-assy-for-sale
Parts are going to be salvage yard items.
KirkF
24
Nov 6, 2024 11:35 AM
56exp
Sep 20, 2023 04:41 PM
MannyC750
Dec 16, 2021 03:27 PM
Christmas
13
May 18, 2021 11:06 PM
