I just got a 1971 f500 from one of my customers. Thing is in great shape little to know body rust/frame is spotless. I own an auto shop in north jersey. I will making this into a truck for myself. 5.9 cummins swapped with an allison transmission.
I have been doing a ton of looking but cant seem to find anything on the f500/f600 as im guessing they were not as popular as the smaller trucks. Im wondering what front axles can you replace in the front so I can have disc brakes? Also is 4x4 conversion possible? Any website or info would be great when I get sometime I will post some pictures of the truck on here.
If you are swapping in an oil burner, you will find the stock gearing to be quite limiting.
If you want a better ratio and updated brakes, you will have to swap both the front and rear axles. A later model F450-550 might be a place to look.
Steering gear will be an issue, but you'll have to sort that out depending on the axle you get.
F500 & 600 were very popular, but did sell in smaller numbers than pickups and many were worked to death or near it and reside in or behind barns on abandoned farms.....
Awesome thanks....i know I have a project ahead of me but i love a good headache..
you know of any utility bodies that might fit this thing
