Hunting down misfire issue...
Old Mar 30, 2025 | 05:08 AM
RLXXI's Avatar
RLXXI
Originally Posted by tbear853
Those missing ground straps likely went out an exhaust valve and got caught up in a cat maybe, but they didn't go through the engine.
How exactly do they NOT go thru the engine to get stuck in the cats? LOL have another cup of coffee.
Old Mar 30, 2025 | 10:01 AM
G2IC_Wraith's Avatar
G2IC_Wraith
If they left the cylinder, that is what happens to them.
Old Mar 30, 2025 | 12:07 PM
tbear853's Avatar
tbear853
Like .... They are thin, light ground straps, I don't see one fighting it's way upstream through a momentarily open intake valve with an in-rushing air/fuel mix coming into the cylinder at high velocity.
Old Mar 31, 2025 | 12:30 PM
S.Niekamp's Avatar
S.Niekamp
Thanks for the peace of mind, it's great having the truck running properly again. It still has a slight miss at idle, but I'm wondering if that could be other worn components like cam phasers? I see from reading on the forum that a slight rough idle is rather common on these 5.4 Tritons...
Old Mar 31, 2025 | 05:24 PM
redfishtd's Avatar
redfishtd
Wow that's a lot of blowby on those plugs . That hot gas pushing by plug threads then on the intake the rush of oxygen going by acts like a cutting torch on those white hot plugs. Hope you got new boots too . I encourage everyone to do their own plugs every 60k . You time is free and you can afford to double check and do it right. That carbon around the plug tip it very tough so if you can use some carb cleaner to dissolve it on a cool engine let it soak awhile doing it several times . No additive can burn that out. That hard carbon can break plugs going in and out. That's why I still use nickel anti seize -just a little and a minor amount on threads .
F150Dad
1997 - 2003 F150
Jan 31, 2019 04:51 PM
xtal_01
Modular V10 (6.8l)
Dec 10, 2015 09:11 AM
nikbait
1997 - 2003 F150
Feb 16, 2015 11:47 PM
jbush1721
1997 - 2003 F150
Nov 4, 2012 12:37 PM
bodinejcs
Modular V8 (4.6L, 5.4L)
Dec 8, 2003 10:51 PM
