F100 Speedometer issue.
Old Mar 17, 2025 | 09:41 PM
black33ford's Avatar
black33ford
I'm almost done restoring my 1966 F100. Having trouble with the speedometer. When the truck is not moving, it sits at 100. When moving, the needle moves clockwise, so I know the cable is hooked up. This was not a problem before disassembly. Any ideas?
Old Mar 17, 2025 | 11:25 PM
rusty valley's Avatar
rusty valley
Did you remove the needle? are you sure its not bent , or the back ground plate is not seated correctly?
Old Mar 18, 2025 | 06:43 PM
black33ford
Figured it out. I took the speedo assy out and moved the needle back to zero. Works now. Why it had been moved over to 100, I have no idea.
Old Mar 18, 2025 | 09:38 PM
rusty valley
good for you, problem solved. needle sits at rest against a post, you must have bumped it off fiddling around with it. carry on!
Tate Schaffer
Mar 21, 2022 10:39 AM
ryancawby
16
Mar 20, 2019 01:31 PM
rtcapo
Aug 26, 2018 08:18 PM
overlandexpress
Sep 29, 2009 11:09 PM
Joe fix it
Jun 20, 2009 05:58 PM
