Engine oil preluber
Old Mar 16, 2025 | 06:27 PM
speakerfritz's Avatar
speakerfritz
Engine oil preluber
Dc motor driven oil pump…runs at key on…shuts off once mechanical pump kicks in…check valve prevents reverse motoring.
Old Mar 16, 2025 | 06:28 PM
speakerfritz
Old Mar 16, 2025 | 07:36 PM
speakerfritz
Here’s a version that doesn’t use a dc motor…it uses an accumulator instead.
Old Mar 16, 2025 | 09:33 PM
powerboatr's Avatar
powerboatr
https://youtu.be/MTR9HyM3Ve0
we had some like those in a few boats, not same brand...but same principle
Accumulator recharges after start
Then provides oil under low pressure or switched to push oil on start up
Havent seen one in awhile
Old Mar 16, 2025 | 09:40 PM
kayakingpoodle's Avatar
kayakingpoodle
I have used the accumulator style on a few race engines, they work great, but are easy to forget the manual of arms so to speak and leave them uncharged.
I look forward to seeing what your research turns up on the electrical pump system. It is something I have thought about looking into.
Old Mar 16, 2025 | 10:14 PM
WK15's Avatar
WK15
Could this work?
Welcome to Preoil.com
I thought about this for Lincoln but I never thought about this for the 6.7L.
Old Mar 16, 2025 | 10:26 PM
kayakingpoodle
That's an accumulator style. With a solenoid. I ran a manual valve on the ones I used in the past. And yes it will work depending on the volume of oil it stores.
John in OkieLand
Feb 1, 2025 05:49 AM
94yj
May 24, 2023 11:02 AM
bismic
Dec 5, 2010 12:09 PM
ghunt
General Diesel Discussion
Jul 22, 2007 03:23 PM
