New wheels
Old Mar 12, 2025 | 06:21 AM
Red Rascal's Avatar
Red Rascal
New wheels
I am thinking of replacing my tires and steel wheels on my 2020 Ford F150 XL, automatic trans, 4x4, extended cab. I would like to upsize the tires and wheels to alloy 18s or 20s; HOWEVER, this may not be worth the effort. My question is: What would I have to change/modify on my truck to make everything, speedometer, cruise control, etc, work? I would like to hear from someone that has actually made the switch?
My previous truck was old enough that I just had to replace the speedometer output gear on the trans tailshaft.
Thanks in advance!
Old Mar 12, 2025 | 08:28 AM
scott91370's Avatar
scott91370
If you go up in overall tire size (wheel size does not matter) you can use Forscan to make changes so the speedometer will read the correct speed. You could also buy a tuner that will do this but there is the cost of the tuner associate with that.
If you do not change the speedometer, everything will work as it should but your speed will be off by X%.
Old Mar 12, 2025 | 08:37 AM
Red Rascal's Avatar
Red Rascal
Thanks for the info Scott!!
Old Mar 12, 2025 | 09:42 AM
GlueGuy's Avatar
GlueGuy
You can change the wheel size if you switch to a different tire profile that has the same OD as the original tire and not have to change anything.
If you look at new trucks with different wheels/tires that's exactly what Ford does so they don't have to change programming at all.
Old Mar 12, 2025 | 10:08 AM
nitebreeze's Avatar
nitebreeze
I replaced and upsized tires on my 2010 and 2014 F150s. When going up only one size taller tire, you don't need to do anything except adjust Forscan tire size if you want accuracy... but not needed otherwise. On the 2014 F150, I first went up only one size taller tire 32" to 33", and then decided to go to 34", and that needed a two inch front suspension level for tire clearance. Changing to a larger diameter rim size does not matter, and going from steel to alloy does not matter. If your rim diamter gets large like 20", you start to diminish road ride comfort from the decreased sidewall. If you go to aftermarket wheels, pay attention to wheel offset. The farther you go from stock wheel offset, you get a chance of creating wheel fender corner rubbing.
Old Mar 12, 2025 | 11:13 AM
JKBrad's Avatar
JKBrad
Look on your local Craigslist, Offer Up, or Facebook Marketplace. You will find many people who have taken brand new, or nearly new tires/wheels off their trucks and are selling them for less than the cost of new tires. I've done this a few times for various vehicles. The only downside is that most people take the TPMS out and transfer them to their new wheels.
Old Mar 12, 2025 | 12:17 PM
Red Rascal's Avatar
Red Rascal
Thaanks JK! I’m getting options, good options!!
Old Mar 12, 2025 | 12:39 PM
JKBrad's Avatar
JKBrad
When choosing aftermarket wheels, pay close attention to backspace/offset, and also choose only hubcentric wheels. Too little offset can cause a weird look and rubbing, even with only 33” tires. A wheel that isn’t hubcentric can cause vibrations, or cause lug nuts to loosen if not mounted and tightened properly.
FreddieM
Nov 27, 2021 01:06 PM
okmike87
2004 - 2008 F150
16
Jun 20, 2007 10:21 PM
powderburn2
2004 - 2008 F150
Jul 19, 2006 07:11 PM
Motorcycle4
2004 - 2008 F150
Sep 24, 2004 05:39 AM
tripp
Nov 5, 2001 09:48 AM
